Slow video on IMX6 Quad with Qt media player
oxffffaa
Hello, i've got IMX6 Quad board and i'm trying to play video using Qt media player. Problem is that framerate is very low, and i see messages "A lot of video buffers are being dropped". And if i use gst-play, or builtin imxplayer, everything is ok. Does anybody know about such problem? Thank You
joanxie
it seems the qt media player doesn't use HW decoding, did you try to use qtmultimedia ?like qmlvideo? this should use HW decoder
oxffffaa
With qml video i see black screen instead of video, i've printed status field of QML MediaPlayer and it look like that video is playing, but i don't see it. Also "A lot of video buffers are being droppen" now disappear.
joanxie
what bsp version do you  use? how did you install qml? let me double check it, did you add qtmultimedia in the local.conf?
oxffffaa
sorry, how to check BSP version?
My board is Seco IMX6 Quad, image is Yocto with X11. I built Qt5.12.3 for imx6 device on my x86 host then run 'make install' and copy result to board. To run Qt  application i use Qt xcb plugin(QT_QPA_PLUGIN=xcb).
oxffffaa
BSP is 6.0
joanxie
it seems that you use the third party software, I tested on nxp yocto bsp before, the qml can support video playing successfully, don't find any delay issue, I don't familiar with your bsp, maybe you need to contact them to improve your video playing performance
oxffffaa
ok, thank you. i'll try yocto
