MCAL integration issue
3,209 次查看
sgp_118
Hi All,
I am trying to use S32K14X_MCAL_4.2_RTM_HF6_1.0.2.exe MCAL with the Vector Autosar SIP. After integrating MCL CDD from this MCAL in DaVinci configurator, I am not able to view or add all the exclusive areas as defined in "mcl_Bswmd.arxml" in Rte -> RteBswModuleInstances -> Mcl -> RteBswExclusiveAreaImpls
Instead I am able to view only a subset of exclusive areas. Is it linked with bswmd file "Mcu_ib_bswmd.arxml" provided with the SIP?
Is there a way to patch "Mcu_ib_bswmd.arxml" file during MCAL integration/generation?
/TS_T40D2M10I2R0/Mcu_ib_bswmd/BswModuleDescriptions/Mcu/McuBehavior
标记 (2)
0 回复数
