How to set up ccm for bluez-meshctl in yocto
1,869 次查看
fgu_bg
Hi there,
I am trying to set up bluetooth meshctl on my i.MX6 using yocto. I have added meshctl and required dependencies in my recipe, but the utility in my image does not start.
Waiting to connect to bluetoothd...Failed to parse provisioning database file prov_db.json
In reference manuals for Raspberry Pi (e.g. Developer-Study-Guide-How-to-Deploy-BlueZ-on-a-Raspberry-Pi-Board-as-a-Bluetooth-Mesh-Provisioner.pd...) the instructions indicate that I need to enable aes-ccm crypto in the kernel. Another post here also links my error to missing aes-ccm: Install meshctl on Raspberry Pi. Follow these instructions to install… | by Lup Yuen Lee 李立源 | Mediu...
In my image I don't see aes-ccm enabled if I run:
cat /proc/crypto | grep ccm
I do see other features for caam, for example:
imx-carbon:/tmp$ cat /proc/crypto | grep aes
driver : cmac(aes-arm)
driver : xcbc-aes-caam
Am I looking in the right spot to see if CCM is enabled? How can I enable ccm in my Yocto recipes?
Thanks for the support!
0 回复数
