How can I use SPI with FXTH87xx?
aliyolcu
I could not run the spi protocol on FXTH. Where am I doing wrong?
I am adding TPMS_MSG_INIT () to add SPI feature. I can see the CLK signal smoothly on the oscillator
to send a value "(UINT8) TPMS_MSG_WRITE ((UINT8) 0xFF);" I use this function, but I'm not sure if I use it correctly. According to my research, I could not find an example of spi on FXTH.
Can you help me with this?
