C++ HTTPS Library recommendation
1,361件の閲覧回数
padakanti
I need to write an C++ based HTTPS server and implement some rest APIs.  Is there any highly recommended opensource framework that I can use?
The server needs to serve large files and so it would help if it supports chunked/streamed file downloads.  Also, couple Post requests with JSON request/response.   The server will be launched dynamically for a period of time from a C++ based service/program that will take actions based on the requests made to the server.
TLS connection has to use OpenSSL library.
タグ(2)
0 返答(返信)
