AMMCLIB and ARM toolchain
sacchi73
I'd like to port the software provided with MCSPTE1AK144 eval board into Keil (ARM toolchain).
I'm stuck trying to link AMMCLIB. There is no specific version for ARM compiler (!!!!!!); I tried every image provided (iar, ghs, s32ds, mingw, vc_x64) but link fails.
Here the following errors I get:
ghs
.\Objects\Bldc.axf: Error: L6283E: Object AMCLIB_TrackObsrv_c.o contains illegal local reference to symbol .
iar
.\Objects\Bldc.axf: Error: L6242E: Cannot link object AMCLIB_TrackObsrv_c.o as its attributes are incompatible with the image attributes.
   ... wchart-16 clashes with wchart-32.
.\Objects\Bldc.axf: Error: L6242E: Cannot link object GDFLIB_FilterMA_c.o as its attributes are incompatible with the image attributes.
.\Objects\Bldc.axf: Error: L6242E: Cannot link object GFLIB_ControllerPIrAW_c.o as its attributes are incompatible with the image attributes.
.\Objects\Bldc.axf: Error: L6242E: Cannot link object GFLIB_IntegratorTR_c.o as its attributes are incompatible with the image attributes.
mingw
.\Objects\Bldc.axf: error: L6008U: Could not recognize the format of member AMCLIB_TrackObsrv_c.o from libS32K14x_AMMCLIB.a.
s32ds
vc_x64
.\Objects\Bldc.axf: error: L6024U: Library S32K14x_AMMCLIB.lib contains an invalid member name.
Is there a way to link the provided images with ARM compiler?
Thank you,
Lorenzo
