[88W9098] - Do this module can support openwrt ?
1,581 次查看
OttoLee
Hi NXP community :
    We have new production , and will use wifi module(use 88W9098 DB CDW 2x2 802.11ax, Bluetooth 5.1)
     and we got the source code from "PCIE-WLAN-UART-BT-9098-U16-X86-17.68.1.p38-17.26.1.p38-MXM4X17222.P1_V0V1-GPL" , and we try to merge to Openwrt system , but encounter difficulty , it's hard to merge .
      I check Makefile and find below
     # OpenWrt support
     CONFIG_OPENWRT_SUPPORT=n
    Does this mean not support for openwrt system ?
    And if I can generate *.ko  on Linux system first, then push these *.ko file to embedded system ?
0 回复数
