SD FMU card not found
3,242件の閲覧回数
dolphin5243
We assembled the fmuk66-drone for the first time and completed the sensor part of the airframe setting in the QGroundControl program.
However, in the radio setting, 7 pins came instead of JST-GH 6 pins, which was solved by buying a JST-GH kit.
After that, the radio setup was completed, but suddenly there was a problem with the gas sensor setup.
The SD FMU Card is not detected, and accordingly only the error message that the gyros sensor is not recognized has been printed.
I'd like to ask you a detailed solution about this.
I've already assembled it and it's been a long time. We hope that solutions such as returns will be the last resort. Give me a practical solution.
0 返答(返信)
