Blown voltage regulator?
mshoaib
Hello! My flight controller doesn't power on from battery but works perfectly fine when powered from USB. I'm suspecting that the voltage regulator has fried up. I needed help in locating and removing the voltage regulator from the board so I can connect an external BEC in order to power up the flight controller. I have been trying to fix this from past few months, I'd really appreciate it if I could get a little help
The flight controller Im using is RDDRONE-FMUK66
