Blown voltage regulator?
1,746 次查看
mshoaib
Hello! My flight controller doesn't power on from battery but works perfectly fine when powered from USB. I'm suspecting that the voltage regulator has fried up. I needed help in locating and removing the voltage regulator from the board so I can connect an external BEC in order to power up the flight controller. I have been trying to fix this from past few months, I'd really appreciate it if I could get a little help
The flight controller Im using is RDDRONE-FMUK66
0 回复数
