floating point to fractional conversion
fasihahmed
Hey,
I have a sample code using calculations in floating point, that i want to use on my MC56F82748 DSC platform using using fractional maths  so i can use the FSESL libraries. Especially the ''GFLIB_ControllerPIp'' function which uses scaling for its gains input.
Is there any guide or step i should follow to ensure correct conversion/porting?
ZhangJennie‌xiangjun.rongganeshramachandran
xiangjun_rong
Hi, Fasih,
I suppose that you can refer to the DSP56800EXGFLIB.PDF, which I attach it.
Hope it can help you
XiangJun Rong
