SGTL5000 Delay between Audio In and I2S Transmission
davebrown
does anybody know the exact delay of the SGTL 5000 between the Audio In (Line/Mic) and the start of  the corresponding I2S transmission frame. I need this for exact audio measurement. Also of interest for me is the delay between completion of a I2S receive frame and the corresponding audio signal at the line output.I expect this to be dependent on the clocking and inserts of e.g. the filterbanks but I cannot find this datas in the manual.
Maybe someone can help.
regards
Dave Brown
TICS_Fiona
Hello Dave
I would suggest submitting a case for this issue.
https://community.freescale.com/docs/DOC-330215
Best Regards
Fiona Kuang
TIC - Technical Information Center
