Problem with programing old DSP56303 using parallel port
1,918件の閲覧回数
ArkadyB
Hello, I have difficulties with programing old DSP56303 using parallel port.
I need any solution to program this DSP.
if is needed a JTAG USB Programmer, I can buy it too.
タグ(1)
1,800件の閲覧回数
Hello @ArkadyB
This part is too old. I searched for some information from our internal resources. This part only supports parallel connection.
If you are in the pre - development stage, I highly recommend that you switch to other new NXP MCUs. Please describe your detailed requirements, and I will help you in making recommendations.
Alice
