New FSLESL: Embedded Software Motor Control and Power Conversion Libraries 4.x
3,683 次查看
GottiLuca
I've seen Freescale has published the new Freescale Embedded Sofwtare Motor Control Libraries ( so called FSLESL ) , now the more recent one is 4.2 ( see : http://www.freescale.com/products/arm-processors/kinetis-cortex-m/v-series/embedded-software-motor-c...   ).
While in the last FSLES before 4.x ( i.e. version 3.0 ) on the documentation there was alwasy the execution time ( min, max ) in CPU cycles, now such information is missing.
I think that this missing information is critical for the embedded designer that, like in our case, has to use such product in a high real time system , i'm peaking about of motor control algorithms called on the occurence of a periodic interrupt with frequency quite high ( >= 8 KHz ).
So, my question is why such a fundamental information is missing now ..
3,261 次查看
TICS_Fiona
Hello Luca
I have contacted the developer team for this doc issue, and will reply you as soon as I get the answer.
Fiona Kuang
Technical Information & Commercial Support
3,261 次查看
TICS_Fiona
Hello Luca
I have sent the performance data to you by email.
Best Regards
Fiona
3,262 次查看
TICS_Fiona
Hello Luca
Fiona Kuang
