NTB0104BQ-Q100X
NTB0104BQ-Q100X
1,020件の閲覧回数
beyondiv1986
Hi, I have a question about the use of the NTB0104BQ-Q100X.
From the NXP website, I know the  NTB0104BQ-Q100X is only suitable for the push-pull circult, and from the datasheet, It says   "the NTB0104-Q100 is not recommended for use in open-drain driver applications such as 1-Wire or I2C."
My question is "Could I use the NTB0104-Q100 just accept the output of  an open-drain driver , and transmit the signal to a   push-pull circult (only use for one direction: from OD to PP)"
THANKS! ^_^
0 返答(返信)
