MPC777C_eTPU_inputcapture
1,803 次查看
dreamtea81125
Hi NXP
I have question about input capture by eTPU.
I can use PWM function.
So i connected the pin of PWM with the pin of input capture.
but i didn't capture any signal by input capture function.
What's wrong with my code ?
There are my code. thank you.
Any advice is helpful.
标记 (3)
1,711 次查看
PetrS
most probably the IGF filter, which is added on some pins, is not properly set.
You can refer to below example for frequency measuring;
https://community.nxp.com/docs/DOC-343522
BR, Petr
