LS1043 USDPAA memory issue
2,075 次查看
Diligent_06
I'm completing experiments with NR5G cell search using a combination of LS1043+LA9310, but running the official nmm test program, nmm-test, will report an error about USDPAA memory and won't work properly. Then I checked the U-Boot information and found that there is an error message "No USDPAA memory, no 'fsl,usdpaa-mem' in device-tree" in U-Boot. The current system image is the official LS1043ARDB image, but I still have this problem.
1,988 次查看
yipingwang
Please use dts file arch/arm64/boot/dts/freescale/fsl-ls1043a-rdb-usdpaa.dts
