IMX8M PLUS EVK : Display over Type-c usb (DP ALT mode)
bych
Hello team,
I would like to ask if imx8m plus evk board (linux) has DP ALT mode.
I'm trying to connect LCD panel via type-c to hdmi cable.
However, whenever I connect the cable from the board to monitor, the display doesn't show up. (Cable and the monitor work normally when I tested)
Can anyone advise me how to get the display from type-c usb?
Should I modify the kernel source in order get DP ALT mode?
KEVINKUO
I CAT NOT BELIEVE NXP DONOT SUPPORT THIS NORMAL FUNCTION
JorgeCas
Sorry none of i.MX devices supports DP ALT mode.
Best regards.
%3CLINGO-SUB%20id%3D%22lingo-sub-1937293%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX8M%20PLUS%20EVK%20%3A%20Display%20over%20Type-c%20usb%20(DP%20ALT%20mode)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1937293%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20team%2C%3C%2FP%3E%3CP%3EI%20would%20like%20to%20ask%20if%20imx8m%20plus%20evk%20board%20(linux)%20has%20DP%20ALT%20mode.%3C%2FP%3E%3CP%3EI'm%20trying%20to%20connect%20LCD%20panel%20via%20type-c%20to%20hdmi%20cable.%3C%2FP%3E%3CP%3EHowever%2C%20whenever%20I%20connect%20the%20cable%20from%20the%20board%20to%20monitor%2C%20the%20display%20doesn't%20show%20up.%20(Cable%20and%20the%20monitor%20work%20normally%20when%20I%20tested)%3C%2FP%3E%3CP%3ECan%20anyone%20advise%20me%20how%20to%20get%20the%20display%20from%20type-c%20usb%3F%3C%2FP%3E%3CP%3EShould%20I%20modify%20the%20kernel%20source%20in%20order%20get%20DP%20ALT%20mode%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2138894%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8M%20PLUS%20EVK%20%3A%20Display%20over%20Type-c%20usb%20(DP%20ALT%20mode)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138894%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20CAT%20NOT%20BELIEVE%20NXP%20DONOT%20SUPPORT%20THIS%20NORMAL%20FUNCTION%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1938745%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8M%20PLUS%20EVK%20%3A%20Display%20over%20Type-c%20usb%20(DP%20ALT%20mode)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1938745%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3ESorry%20none%20of%20i.MX%20devices%20supports%20DP%20ALT%20mode.%3C%2FP%3E%0A%3CP%3EBest%20regards.%3C%2FP%3E%3C%2FLINGO-BODY%3E
