Classic CW and P&E Micro
miroslavmartise
Hello everybody,
at the moment I am solving an interesting problem: I need to connect P&E Micro FX tool to classic CW (5.9), but some errors occured. Mainly, there is not any possibility to select this tool. So, I can use USB Tap and parallel debbuger, but not P&E Micro. With Eclipse version it works very fine. However, in my office I have got one old computer with only classic CW version installed and I have decided to use it recently. Am I stupid man?
Is there any way to solve it? Any patch, etc?
Thank you a lot.
P.S.: I deal with DSCs, only.
Tags (4)
johnlwinters
Parallel port option is best. The hardware is very simple and inexpensive. Second choice is the USB tap for a more expensive complex solution.
There is no way to use the Multilink with the classic CodeWarrior for DSC. There is no plan to develop that.
