About non-overlap time of TEA2016AAT
4,507 次查看
YorkZHU
Hello, I notice that in Chapter 18, the minimum non-overlap time is 200ns, but after calculating the deadtime of LLC under 300kHz, the optimal deadtime is 73ns. In this case, I hope you will give a constructive help or advice, how could I optimize the parameter. Thanks!
4,454 次查看
guoweisun
6 回复数
4,457 次查看
guoweisun
it doesn't include 150ns.
4,456 次查看
YorkZHU
The deadtime I get from external pin is 50ns or 200ns?
4,455 次查看
guoweisun
200ns.
4,442 次查看
YorkZHU
Fine.
4,472 次查看
guoweisun
You should follow this parameter specification of this IC.
4,469 次查看
YorkZHU
If I need MOSFET working in the best frequency, I have to set the minimum non-overlap time parameter by using RDK01DB1561 development programming board?
Besides, I need to know whether the minimum non-overlap time 200ns contains the fixed HB intern delay time 150ns. I mean 150+50ns. Or 50ns contains HB intern delay time.
