82748 CW debug CpuUnhandledInterrupt problem
2,588 次查看
terrybogard
dear NXP expert,
sometimes I debug the program, but the start point is not main function, but the point in the figure. and the program is run unexpected. what's the problem?
2,585 次查看
xiangjun_rong
Hi, Terry,
I think your code has issue,  you have to track down the interrupt source and take action to correct the code.
In order to find out which code line leads to the interrupt triggering, I suggest you set break  and get the line, or run the code step by step.
Hope it can help you
XiangJun Rong
2,582 次查看
terrybogard
any suggestion about which kind of issue will lead to the problem?thanks.
2,576 次查看
xiangjun_rong
I can not tell you which kind of issue will lead to the problem, I suggest you run the application code one by one and check which line leads to the issue.
XiangJun Rong
