56F80x SPI receiver lookup issue
1,720件の閲覧回数
Aili
I found 56F807 SPI receiver (slave mode) is not able to re-initialize if it misses clock. I have to physically recycle the power to have it work again. Does anyone have solutions?
This issue was also reported here but nobody answered: www.dsprelated.com / showthread/motoroladsp / 1274-1.phphttp://www.dsprelated.com/showthread/motoroladsp/1274-1.php
Liping
1,565件の閲覧回数
xiangjun_rong
Hi, LiPing,
Sorry for the delay. Regarding your question, I suppose that you want to reinitialize the SPI receiving shift register, as you know the SPI receiving shift register is invisible by7 software. In the case, I suggest you clear the CPHA bit,  the SPI receiving shift register will be initialized after the falling edge of chip select signal /SS with the CPHA bit cleared.
Hope it can help you.
Xiangjun Rong
