working with MCF54455EVB-->need help
1,639 次查看
manoj
hi,
while programming external flash of mcf54455EVB using codewarrior i am getting "0x00005850 bytes of Target Memory at 0x40000500 is not within flash boundaries."  this error message. i dont know where i am wrong. please help.
749 次查看
kmahan
You should check your configuration.  SDRAM is located at 0x40000000.
749 次查看
manoj
i checked in the configuration. SDRAM is at 0x40000000 only. but the same error i am getting.
