how to move function in ram memory
3,741 次查看
ajaybharti
Hi Support,
could any one tell how to create a user ram section in cold fire device and move specific function to this memory.
regards,
Ajay
3,474 次查看
ZhangJennie
I suggest you check AN4329 that contains the information you need
3,475 次查看
ZhangJennie
3,473 次查看
ZhangJennie
I attach it for your convenience,
see 5 Relocating Code and Data in Internal RAM
3,473 次查看
ajaybharti
Hi Jennie,
I had seen the application note and constructed one code but during compilation had error coluld you pls. look in to and resolve the issue.
Ajay
