Using BDM on MCF5485
1,759 次查看
nvinod
I am new to uclinux and Linux. I want to debugg (using on board BDM) a custom CPU board based on MCF5485 using PC with Linux OS.
Please help me to start with.
nvinod
1,135 次查看
ChrisJohns
The BDM project on Sourceforge will provide BDM support for GDB. See http://bdm.sourceforge.net/.
If you are debugging applications I suggest you use the uClinux gdbserver rather than BDM. If you are debugging the kernel then BDM may help but you need to know what you are doing. I once had some code in the BDM package to help GDB with some of the trap 0 (I think) in uCLinux. It may be needed and should be around in the version control for the BDM project.
Chris
