USB Detach detection
1,442 次查看
salman83
I am using MCF52259DEMOMCU for my project. I am currently working on the USB which is communicating with the PC side software perfectly fine. I just want to know any status bit or interrupt when the usb gets detached from the PC.
Also, i am using the usb in device mode only, not in host mode or OTG.
Any help will be highly appreciated.
Regards.
1,297 次查看
yibbidy
Have you checked the Interrupt Status Register (OTG_STAT)?
Bit 0 may do what you want:
VBUS Valid
0 The VBUS voltage is below the A VBUS Valid threshold
1 The VBUS voltage is above the A VBUS Valid threshold
Shaun
