TCP Client Abord-PowerOff Notification...
2,565 次查看
SKumar
Hi all,
              I am using MCF52235 EVB on codewarrior environment.
              I am using uTaskser operating system.
              I have built up client server application.
              Problem is whenever client get shutdown in unusual way ( ie. Abort, Power off ) server not get
              notification that client is closed...which it get when we reset the board...
               Is anyone have any idea how to send notification to other board when any of two connected board get disconnected in unusual manner.
              Thank you....
kumar
1,588 次查看
Nouchi
Senior Contributor II
To detect which client is disconnected, server have to send periodically message to test client, if client does not respond in time, the server can consider the client disconnected.
Emmanuel
1,588 次查看
SKumar
Thanks a lot. That is great help.
kumar.
