SetStopMode
SetStopMode
1,417 次查看
néfiarmelim
Hello, I am using MC51EM in a project and now I need to apply the SetStopMode function , I use the Processor Expert 6.3. However, the option help doesn't have the example.
I need the minimum consumption in my application.
I read the chapter 6 of reference manual, but how I apply it?
I get to use the function but the MCF51EM doesn't back to work, How can I do it?
标记 (2)
1,347 次查看
miduo
To activation SetStopMode function it is necessary to enable STOP instruction. The "Clock settings - Low Power Mode settings - STOP instruction enabled" property should be set to "yes" value in CPU Inspector window - Properties page.
