SD card I/O error
13,514件の閲覧回数
mendelbullex
We have successfully used our SD card to output an audio file on our M54451EVb. WE started working on other things and eventually came back to it without changing the BSp installed. We no longer can use the SD card and get the following message:
mmc0: host does not support reading read-only switch. assuming write-enable.
mmc0: new SD card on SPI
mmcblk0: mmc0:0000 SD02G 1.83 GiB
mmcblk0: p1
mmcblk0: retrying using single block read
mmcblk0: error -38 sending status comand<3>mmcblk0: error -38 sending read/write command, response 0x4, card status 0xff04
end_request: I/O error, dev mmcblk0, sector 3842041 Buffer I/O error on device mmcblk0p1, logical block 3841904
end_request: I/O error, dev mmcblk0, sector 3842042 Buffer I/O error on device mmcblk0p1, logical block 3841905
end_request: I/O error, dev mmcblk0, sector 3842043 Buffer I/O error on device mmcblk0p1, logical block 3841906
end_request: I/O error, dev mmcblk0, sector 3842044 Buffer I/O error on device mmcblk0p1, logical block 3841907
end_request: I/O error, dev mmcblk0, sector 3842045 Buffer I/O error on device mmcblk0p1, logical block 3841908
end_request: I/O error, dev mmcblk0, sector 3842046 Buffer I/O error on device mmcblk0p1, logical block 3841909
end_request: I/O error, dev mmcblk0, sector 3842047 Buffer I/O error on device mmcblk0p1, logical block 3841910
end_request: I/O error, dev mmcblk0, sector 3841977
end_request: I/O error, dev mmcblk0, sector 3841978
end_request: I/O error, dev mmcblk0, sector 3841979
end_request: I/O error, dev mmcblk0, sector 3841980
end_request: I/O error, dev mmcblk0, sector 3841981
end_request: I/O error, dev mmcblk0, sector 3841982
end_request: I/O error, dev mmcblk0, sector 3841983
end_request: I/O error, dev mmcblk0, sector 3841984
end_request: I/O error, dev mmcblk0, sector 3841985
end_request: I/O error, dev mmcblk0, sector 3841986
end_request: I/O error, dev mmcblk0, sector 3841987
end_request: I/O error, dev mmcblk0, sector 3841988
end_request: I/O error, dev mmcblk0, sector 3841989
end_request: I/O error, dev mmcblk0, sector 3841990
end_request: I/O error, dev mmcblk0, sector 3841991
end_request: I/O error, dev mmcblk0, sector 3841992
end_request: I/O error, dev mmcblk0, sector 7673
end_request: I/O error, dev mmcblk0, sector 7674
end_request: I/O error, dev mmcblk0, sector 7675
end_request: I/O error, dev mmcblk0, sector 7676
end_request: I/O error, dev mmcblk0, sector 7677
end_request: I/O error, dev mmcblk0, sector 7678
end_request: I/O error, dev mmcblk0, sector 7679
end_request: I/O error, dev mmcblk0, sector 7680
end_request: I/O error, dev mmcblk0, sector 7681
end_request: I/O error, dev mmcblk0, sector 7682
end_request: I/O error, dev mmcblk0, sector 7683
end_request: I/O error, dev mmcblk0, sector 7684
end_request: I/O error, dev mmcblk0, sector 7685
end_request: I/O error, dev mmcblk0, sector 7686
end_request: I/O error, dev mmcblk0, sector 7687
end_request: I/O error, dev mmcblk0, sector 7688
Does anyone know what the problem is?
6,562件の閲覧回数
mendelbullex
Turned out we just needed to reformat the card, completely rebuilding the patitions
7 返答(返信)
6,563件の閲覧回数
mendelbullex
Ok, I take it back, the single block read after error is already implemented in the kerenel, therefore, I have no idea what is causing this problema dn would love any feedback that anyone can give me.
6,563件の閲覧回数
mendelbullex
6,562件の閲覧回数
IRTrans
what speeds do you get when reading from the SD card?
We also tested it, however the speed was only about 100KByte/s which made it unusable for us.
An USB stick in comparison is rather fast with around 10MByte/s.
Marcus
6,562件の閲覧回数
TomE
Specialist II
That development board runs the SD cards from the DSPI.
The "lowest common demonimator" speed is 400kHz for "low speed SDIO cards". Other ones should be able to run at up to 25MHz. Check Wikipedia for details on the different speed ratings.
The software you're using may not be switching to a higher clock rate when it could be. It may also not be using the DMA as well as it might.
Tom (A Random Poster)
6,562件の閲覧回数
IRTrans
Thank you for the info.
We are using LINUX - no idea if the LINUX device driver uses the correct clock frequencies.
Marcus
6,562件の閲覧回数
TomE
Specialist II
Linux code is most likely to be "lowest common denominator" code.
There's a huge amount of code in the Linux driver stack but you're looking for the "low level platform setup" and the DSPI driver code. You don't have to understand all of it, just "pattern match" with the code that writes the relevant DSPI control registers and find what it is doing. Then try increasing the speed and see what happens.
6,562件の閲覧回数
mendelbullex
Ok, so it looks like the error is being caused by a multi block read on the final block when the card is first inserted. It looks like the solution is to do a single block read for the last block. Is there a patch out there that fixes this, or does anyone know how best to add this to the SD driver for linux kernel 2.6.29?
