Read direct from a Memory address
PEGE
Hello i am using a MCF5282,
and i want to buid a loop in C which reads the memorycontent from on adress to another adresse. for example from 0x4000 to 0x8000. in the mcf i have the option to read directly from the sram with RAMBAR_ADDRESS[var] (from 0x20000000).
I am interesetd if someone knew an opportunity to read direct from the whole space of memory for example from 0x0 till 0x7FFFFFFF.
regards Peter
angelo_d
Senior Contributor I
Hi PEGE,
i would say this is a simpel C exercise (untested)
/* setup your src and dest */
unsigned long volatile * src=(unsigned long volatile *)(RAMBAR+0x4000);
unsigned long volatile * dst =(unsigned long volatile *)(RAMBAR+ ....) ;
for ( ; src<0x8000 ; )
      *dst++ = *src++;
regards,
angelo
