Problems using Windows 10 and  AN3927 (USB Bootloader MSD) framework, SF734138
2,531 次查看
dirkricker
Fresh Out Contributor
I am currently using the  AN3927 (USB Bootloader MSD) framework to update our product that uses a MCF51JM128.  I am having issues with updating the firmware with Windows 10.  It pops up as a drive on my host computer and I am able to copy to it, but after reboot it always fails with a SF734138 error.  Still works fine with Windows 7, but less and less of our customers have a machine running 7 or XP.
2,348 次查看
miduo
Actually I am still not updated to WIN 10. So for your case, you may make reference below tread:
https://mcuoneclipse.com/2013/12/14/new-pe-opensda-firmware-v114/
P&E had update the OpenSDA driver for Win 8.1, not sure if work for Win 10, You can try.
2,348 次查看
dirkricker
Thanks Fang, I will give this a look
