Porting AN3927 (USB Bootloader MSD) to CodeWarrior v10.6 for mcf51jm128?
2,111 次查看
dirkricker
Does anybody know if AN3927 (USB Bootloader MSD) can be ported over to CW10.6?  Been looking at AN4379, but I'd like to stick with AN3927 if possible.  Thanks!
标记 (3)
1,855 次查看
TomE
Specialist II
1,855 次查看
dirkricker
I got it working by dragging the files in and getting everything done manually.  My biggest problem was getting the program to use __Entry as a starting point instead of __startup.  I finally found in Properties->C/C++ Build->Settings->ColdFire Linker->Input that there is a place to specify an Entry Point.  I put __Entry in instead of __startup and that fixed me up.
