PIT 1s on the M5373EVB
Stefou
Hello everybody
How do you program a working PIT which calls every second an interrupt service routine on a M5373EVB evaluation board.
Can anybody explain me the code to do that?
Thank you
RichTestardi
Senior Contributor II
I have not used the 5373, but it looks like the PIT is similar to the 52221.
If it helps, I previously posted my 52221 code here:
Good luck!
-- Rich
