Need info on ColdFire MCF5483 Microcontroller
2,991 次查看
Ebda
Dear all,
We have developing an application "Process control and monitoring over Ethernet" and i selected the microcontroller MCF5483 and decided to use an RTOS we found they are very expensive. Finaly we decided to use embedded linux as OS, I need the infromation on the following points
  1. A multitasking Linux operating system/kernal and compiler for coldfire MCF5483.
  2. We also require firmware components such as drivers, TCP/IP stack, HTTP server, DHCP client (The ability to assign an IP address to the device) and Telnet interface.
  3. Developmental kit for MCF5483 Microcontroller and Compiler.
  4. Programmer.
Please any body suggest me regarding the above.
Ebda
标签 (1)
1 回复
1,298 次查看
UK_CF_FAE
FreescaleMCF547x & MCF548x 2.6 Kernel BSP (PCS compatible and non-PCS compatible versions) is here:
You could start your search for the components you describe by going to the MCF548x product page on our site, go to www.freescale.com and make a part number search on MCF5483.
Development kit is M5485EVB and the programmer is included.
Good luck,
Mark
