Need Feedback on ColdFire TCP/IP stack - next release
4,589 次查看
ericgregori
Fixes in the works:
      DNS, DHCP, and packet buffer allocation.
      The packet buffer allocation fix will reduce the RAM requirements in high volume networks.
I know there are more issues, Please email me with any issue you have found .
1,891 次查看
DarrenSteadman
Do you have a rough time scale for when the next release will be available? Also could you give a list of what changes are going to be made?
1,891 次查看
Petter_fupp
At least the default rx window size should be fixed. The result will be far less ACK packets and severely increased performance. Solution is described in this thread.
Cheers,
Petter
