Need Feedback on ColdFire TCP/IP stack - next release
4,525件の閲覧回数
ericgregori
Fixes in the works:
      DNS, DHCP, and packet buffer allocation.
      The packet buffer allocation fix will reduce the RAM requirements in high volume networks.
I know there are more issues, Please email me with any issue you have found .
1,827件の閲覧回数
DarrenSteadman
Do you have a rough time scale for when the next release will be available? Also could you give a list of what changes are going to be made?
1,827件の閲覧回数
Petter_fupp
At least the default rx window size should be fixed. The result will be far less ACK packets and severely increased performance. Solution is described in this thread.
Cheers,
Petter
