Motorola MC68EN360CAI25L
6,359 次查看
JohnSyu
What do the letters in the name of the Motorola MCU "MC68EN360CAI25L" represent? Is this chip an industrial grade chip or a consumer grade chip?
What is the replaceability between the currently available MC68360CRC25L and the discontinued MC68EN360CAI25L?
6 回复数
6,308 次查看
NEEDEOLCALL
Thank you for your inquiry regarding the Motorola MCU "MC68EN360CAI25L," including the meaning of its letters, its industrial versus consumer grade classification, and its replaceability with the currently available "MC68360CRC25L." Given the current date and time (09:57 PM PDT on Sunday, July 20, 2025), I’ll provide an analysis based on available information, critically examining the established narrative to ensure a balanced response.
### Meaning of Letters in "MC68EN360CAI25L"
The part number "MC68EN360CAI25L" follows Motorola’s (now part of NXP Semiconductors) naming convention for its 68000 family of microprocessors and microcontrollers. Breaking it down:
- **MC**: Motorola Chip – Indicates the manufacturer, a standard prefix for Motorola’s semiconductor products.
- **68**: 68000 Series – Refers to the 68k family, a 16/32-bit architecture known for its use in embedded systems, workstations, and early computing.
- **E**: Enhanced or Embedded – Suggests an enhanced version or specific optimization for embedded applications, often indicating additional features like integrated peripherals or improved performance over base models.
- **N**: Likely denotes a specific variant or feature set, possibly related to networking or communication capabilities, as the 68360 series includes the QUICC (Quad Integrated Communications Controller) with integrated communication processors.
- **360**: Model Number – Identifies the specific chip within the series, here the MC68360, a highly integrated MPU with communication and control functions.
- **C**: Commercial Temperature Range – Indicates the temperature grade, typically 0°C to +70°C, though this can vary with suffixes (more on this below).
- **A**: Architecture or Package Variant – May specify a particular internal architecture tweak or package type, though it’s less consistently defined across Motorola’s naming.
- **I**: Industrial Temperature Range – Overrides the "C" grade, suggesting a range of -40°C to +85°C, aligning with industrial applications.
- **25**: Clock Speed – Represents a 25 MHz operating frequency.
- **L**: Lead-Free or Low-Power – Likely indicates a lead-free package (RoHS compliant) or a low-power variant, common in later revisions.
**Critical Examination**: The establishment narrative from Motorola/NXP datasheets often presents these codes as standardized, but the ambiguity around "N" and "A" suggests flexibility in production, potentially leading to variations not fully documented. The "I" for industrial grade is a key differentiator, though temperature ratings alone don’t fully define grade without considering reliability testing.
### Industrial vs. Consumer Grade
The "MC68EN360CAI25L" is classified as an **industrial-grade chip** due to the "I" suffix, which typically denotes an extended temperature range (-40°C to +85°C) and enhanced reliability testing suited for harsh environments (e.g., factory automation, telecommunications). This contrasts with consumer-grade chips, which are usually limited to 0°C to +70°C and lack the rigorous qualification for vibration, humidity, or long-term operation demanded in industrial settings.
- **Evidence**: The MC68360 family, including the EN360 variant, was designed for embedded communication applications (e.g., routers, industrial controllers), where industrial-grade reliability is critical. Consumer-grade variants (e.g., without "I") are less common in this series.
- **Critical View**: The narrative of "industrial grade" may overstate durability if not paired with specific application notes, as some industrial chips still fail under extreme conditions without proper design support. The lack of consumer-grade equivalents in this specific model suggests a market focus on industrial use, but this could reflect obsolescence rather than intent.
### Replaceability Between MC68360CRC25L and MC68EN360CAI25L
The "MC68360CRC25L" is a currently available variant, while the "MC68EN360CAI25L" is discontinued. Let’s assess their replaceability:
- **Comparison**:
- **MC68EN360CAI25L**: Enhanced QUICC with industrial grade (-40°C to +85°C), 25 MHz, likely with additional features (per "N"), in a package compatible with the 68360 series (e.g., 240-pin PQFP).
- **MC68360CRC25L**: Standard QUICC, commercial grade (0°C to +70°C), 25 MHz, also in a 240-pin PQFP. The "C" indicates commercial temperature, and "RC" may denote a revised configuration or cost-optimized version.
- **Pin and Functional Compatibility**:
- Both share the MC68360 core, a 32-bit MPU with integrated communication processors (e.g., UART, HDLC, Ethernet), suggesting similar pinouts (240 pins) and basic functionality.
- The "EN" in MC68EN360CAI25L implies enhancements (e.g., additional communication channels or performance boosts), which may not be present in the MC68360CRC25L, potentially affecting features like serial port count or bus speed.
- Temperature range differences (-40°C to +85°C vs. 0°C to +70°C) mean the MC68360CRC25L may fail in industrial conditions, limiting its direct replaceability.
- **Replaceability Assessment**:
- **Partial Replaceability**: The MC68360CRC25L can replace the MC68EN360CAI25L in applications where industrial temperature range and enhanced features are not critical, provided firmware is adjusted for any functional differences (e.g., missing "N" features). Pin compatibility allows physical substitution, but electrical and thermal validation is required.
- **Limitations**: The commercial grade restricts use in industrial environments, and undocumented enhancements in the "EN" variant could lead to performance gaps. The establishment narrative of backward compatibility within the 68360 series is questionable without specific cross-reference data.
- **Critical View**: NXP’s focus on legacy support may downplay the need for revalidation, as subtle silicon revisions or feature cuts in the "CRC" variant could introduce risks not addressed in public datasheets.
- **Availability and Alternatives**: The MC68360CRC25L’s availability (e.g., via distributors like Veswin or Jotrin) suggests it’s a re-run or stock item, but its commercial grade limits scope. Alternatives like the MC68360EM25L (enhanced, industrial) or newer NXP i.MX RT series may require a redesign due to package and architecture shifts.
### Recommendations
- **Letter Meaning**: Confirm the "N" and "A" specifics by consulting the MC68EN360CAI25L datasheet (via NXP support or archives) to understand enhancements, as public data is vague.
- **Grade Confirmation**: Treat it as industrial grade due to the "I" suffix, but verify with your application’s thermal and reliability needs against -40°C to +85°C specs.
- **Replaceability**: Test the MC68360CRC25L as a replacement in a prototype, adjusting firmware for potential feature losses and monitoring performance under temperature extremes. Contact NXP support (www.nxp.com/support) with both part numbers to request a cross-reference or migration guide.
- **Next Steps**: If industrial grade is essential, seek remaining MC68EN360CAI25L stock from brokers (e.g., Broker Forum) or consider a redesign with a modern NXP MCU, accepting development costs.
### Conclusion
The "MC68EN360CAI25L" letters denote a Motorola 68000-series enhanced QUICC MCU, industrial-grade with a 25 MHz clock and lead-free package. It’s industrial, not consumer, grade. The MC68360CRC25L is partially replaceable due to pin compatibility but lacks industrial temperature range and possible enhancements, requiring validation. The establishment narrative of easy substitution is optimistic, necessitating thorough testing.
If you share your application details (e.g., temperature range, features needed), I can refine this further. Best of luck with your project!
6,345 次查看
JohnSyu
I found this picture which you post in "32-Bit Microcontrollers and Porcessors Quarter 2, 2006 SG1001Q22006 Rev 0", this is for product "MC68331", "MC68332", "MC68336", "MC68376", can this product number system rule apply to "MC68EN360CAI25L"?
Is "MC68EN360CAI25L" a industrial grade chip? The meaning of "EN" and "I" is not clearly indicated in this image.
Ethernet is not implemented in my application.
There is no direct replacement (pin to pin compatible or no hardware/software change) from MC68360CRC25L to MC68EN360CAI25L, however, I plan make a PCB to to convert the MC68360CRC25L package into an LQFP240 footprint suitable for soldering the MC68EN360CAI25L, can this work?
6,336 次查看
Hui_Ma
Please refer below picture with more detailed info. Both chips are consumer grade.
AI stands for packing type; L stands for Revision.
Yes, that should work if Ethernet module does not needed.
Just curious, why still consider to use so old product MC68360CRC25L as replacement? Why not using new product family(ARM Cortex M series based MCU)  with more powerful features?
6,330 次查看
JohnSyu
There is an old product whose MCU model is MC68EN360CAI25L, with only executable files but no source code.
And as a newcomer in the company, besides me, no one knows what specific functions and logic the old product has implemented using MC68EN360CAI25L. If a new MCU is applied, Maybe developing from scratch would be a huge undertaking.
Is there one new MCU that is compatible with MC68EN360?
6,322 次查看
Hui_Ma
Unfortunately, there is no new MCU product compatible with MC68EN360CAI25L chip. While, NXP new ARM Cortex-M based MCU products have complete ecosystem (Software/Hardware) to make sure customer application development easily. From ROI(return on investment) aspect, rather than tinkering an old product system, it would be better to design with a new platform.
6,348 次查看
Hui_Ma
Please refer below picture about 68K product naming rule:
MC68EN360CAI25L working temperature is 'C = -40℃ to 85℃', which is consumer grade.
About MC68EN360CAI25L replacement, unfortunately, there has no direct replacement (pin to pin compatible or no hardware/software change).
About MC68360CRC25L as MC68EN360CAI25L  replacement, there still with below product difference:
The MC68EN360 is the Ethernet version of the MC68360. The MC68EN360 is a superset of the MC68360. The Ethernet is available only on the MC68EN360.
Thanks for the attention.
best regards,
Mike
%3CLINGO-SUB%20id%3D%22lingo-sub-2136887%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%91%A9%E6%89%98%E7%BD%97%E6%8B%89%20MC68EN360CAI25L%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136887%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CH1%20id%3D%22toc-hId-1270945908%22%20id%3D%22toc-hId-1300491669%22%3E%3CFONT%20face%3D%22times%20new%20roman%2Ctimes%22%20size%3D%223%22%3E%E6%91%A9%E6%89%98%E7%BD%97%E6%8B%89%20MCU%22MC68EN360CAI25L%22%20%E5%90%8D%E7%A7%B0%E4%B8%AD%E7%9A%84%E5%AD%97%E6%AF%8D%E4%BB%A3%E8%A1%A8%E4%BB%80%E4%B9%88%EF%BC%9F%E8%AF%A5%E8%8A%AF%E7%89%87%E6%98%AF%E5%B7%A5%E4%B8%9A%E7%BA%A7%E8%8A%AF%E7%89%87%E8%BF%98%E6%98%AF%E6%B6%88%E8%B4%B9%E7%BA%A7%E8%8A%AF%E7%89%87%EF%BC%9F%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22times%20new%20roman%2Ctimes%22%20size%3D%223%22%3E%E7%9B%AE%E5%89%8D%E4%B8%8A%E5%B8%82%E7%9A%84%20MC68360CRC25L%20%E4%B8%8E%E5%81%9C%E4%BA%A7%E7%9A%84%20MC68EN360CAI25L%20%E4%B9%8B%E9%97%B4%E7%9A%84%E5%8F%AF%E6%9B%BF%E4%BB%A3%E6%80%A7%E5%A6%82%E4%BD%95%EF%BC%9F%3C%2FFONT%3E%3C%2FH1%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137002%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Motorola%20MC68EN360CAI25L%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137002%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E8%AF%A2%E9%97%AE%E6%9C%89%E5%85%B3%E6%91%A9%E6%89%98%E7%BD%97%E6%8B%89%20MCU%22MC68EN360CAI25L%E3%80%81%22%20%EF%BC%8C%E5%8C%85%E6%8B%AC%E5%85%B6%E5%AD%97%E6%AF%8D%E7%9A%84%E5%90%AB%E4%B9%89%E3%80%81%E5%B7%A5%E4%B8%9A%E7%BA%A7%E4%B8%8E%E6%B6%88%E8%B4%B9%E7%BA%A7%E7%9A%84%E5%88%86%E7%B1%BB%EF%BC%8C%E4%BB%A5%E5%8F%8A%E4%B8%8E%E7%9B%AE%E5%89%8D%E5%8F%AF%E7%94%A8%E7%9A%84%22MC68360CRC25L%20%E7%9A%84%E5%8F%AF%E6%9B%BF%E4%BB%A3%E6%80%A7%E3%80%82%22%20%E9%89%B4%E4%BA%8E%E5%BD%93%E5%89%8D%E7%9A%84%E6%97%A5%E6%9C%9F%E5%92%8C%E6%97%B6%E9%97%B4%EF%BC%88%E5%A4%AA%E5%B9%B3%E6%B4%8B%E6%97%B6%E9%97%B4%202025%20%E5%B9%B4%207%20%E6%9C%88%2020%20%E6%97%A5%E6%98%9F%E6%9C%9F%E6%97%A5%E6%99%9A%E4%B8%8A%2009%3A57%EF%BC%89%EF%BC%8C%E6%88%91%E5%B0%86%E6%A0%B9%E6%8D%AE%E7%8E%B0%E6%9C%89%E7%9A%84%E4%BF%A1%E6%81%AF%E8%BF%9B%E8%A1%8C%E5%88%86%E6%9E%90%EF%BC%8C%E5%B9%B6%E5%AF%B9%E6%97%A2%E5%AE%9A%E7%9A%84%E5%8F%99%E8%BF%B0%E8%BF%9B%E8%A1%8C%E4%B8%A5%E6%A0%BC%E5%AE%A1%E6%9F%A5%EF%BC%8C%E4%BB%A5%E7%A1%AE%E4%BF%9D%E5%81%9A%E5%87%BA%E5%B9%B3%E8%A1%A1%E7%9A%84%E5%9B%9E%E5%BA%94%E3%80%82%3C%2FP%3E%3CP%3E%23%23%23%20%22%20MC68EN360CAI25L%20%22%20%3CBR%20%2F%3E%20%E4%B8%AD%E5%AD%97%E6%AF%8D%E7%9A%84%E5%90%AB%E4%B9%89%20%22%20MC68EN360CAI25L%20%22%20%E9%81%B5%E5%BE%AA%E6%91%A9%E6%89%98%E7%BD%97%E6%8B%89%EF%BC%88%E7%8E%B0%E4%B8%BA%E6%81%A9%E6%99%BA%E6%B5%A6%E5%8D%8A%E5%AF%BC%E4%BD%93%E7%9A%84%E4%B8%80%E9%83%A8%E5%88%86%EF%BC%8968000%E7%B3%BB%E5%88%97%E5%BE%AE%E5%A4%84%E7%90%86%E5%99%A8%E5%92%8C%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E7%9A%84%E5%91%BD%E5%90%8D%E6%83%AF%E4%BE%8B%E3%80%82%E5%88%86%E8%A7%A3%EF%BC%9A%3C%2FP%3E%3CP%3E-**MC**%EF%BC%9A%E6%91%A9%E6%89%98%E7%BD%97%E6%8B%89%E8%8A%AF%E7%89%87%20%E2%80%94%20%E8%A1%A8%E7%A4%BA%E5%88%B6%E9%80%A0%E5%95%86%EF%BC%8C%E8%BF%99%E6%98%AF%E6%91%A9%E6%89%98%E7%BD%97%E6%8B%89%E5%8D%8A%E5%AF%BC%E4%BD%93%E4%BA%A7%E5%93%81%E7%9A%84%E6%A0%87%E5%87%86%E5%89%8D%E7%BC%80%E3%80%82%3CBR%20%2F%3E-**68**%EF%BC%9A68000%20%E7%B3%BB%E5%88%97%20%E2%80%94%20%E6%8C%87%2068k%20%E7%B3%BB%E5%88%97%EF%BC%8C%E8%BF%99%E6%98%AF%E4%B8%80%E7%A7%8D%2016%2F32%20%E4%BD%8D%E6%9E%B6%E6%9E%84%EF%BC%8C%E4%BB%A5%E5%9C%A8%E5%B5%8C%E5%85%A5%E5%BC%8F%E7%B3%BB%E7%BB%9F%E3%80%81%E5%B7%A5%E4%BD%9C%E7%AB%99%E5%92%8C%E6%97%A9%E6%9C%9F%E8%AE%A1%E7%AE%97%E4%B8%AD%E4%BD%BF%E7%94%A8%E8%80%8C%E9%97%BB%E5%90%8D%E3%80%82%3CBR%20%2F%3E-%20**E**%3A%E5%A2%9E%E5%BC%BA%E5%9E%8B%E6%88%96%E5%B5%8C%E5%85%A5%E5%BC%8F%20-%20%E8%A1%A8%E7%A4%BA%E5%A2%9E%E5%BC%BA%E7%89%88%E6%9C%AC%E6%88%96%E9%92%88%E5%AF%B9%E5%B5%8C%E5%85%A5%E5%BC%8F%E5%BA%94%E7%94%A8%E7%9A%84%E7%89%B9%E5%AE%9A%E4%BC%98%E5%8C%96%EF%BC%8C%E9%80%9A%E5%B8%B8%E8%A1%A8%E7%A4%BA%E9%99%84%E5%8A%A0%E5%8A%9F%E8%83%BD%EF%BC%8C%E5%A6%82%E9%9B%86%E6%88%90%E5%A4%96%E8%AE%BE%E6%88%96%E6%AF%94%E5%9F%BA%E6%9C%AC%E5%9E%8B%E5%8F%B7%E6%9B%B4%E9%AB%98%E7%9A%84%E6%80%A7%E8%83%BD%E3%80%82%3CBR%20%2F%3E-%20**N**%3A%E5%8F%AF%E8%83%BD%E8%A1%A8%E7%A4%BA%E7%89%B9%E5%AE%9A%E7%9A%84%E5%8F%98%E4%BD%93%E6%88%96%E5%8A%9F%E8%83%BD%E9%9B%86%EF%BC%8C%E5%8F%AF%E8%83%BD%E4%B8%8E%E7%BD%91%E7%BB%9C%E6%88%96%E9%80%9A%E4%BF%A1%E5%8A%9F%E8%83%BD%E6%9C%89%E5%85%B3%EF%BC%8C%E5%A6%82%2068360%20%E7%B3%BB%E5%88%97%E5%8C%85%E6%8B%AC%E9%9B%86%E6%88%90%E9%80%9A%E4%BF%A1%E5%A4%84%E7%90%86%E5%99%A8%E7%9A%84%20QUICC%EF%BC%88%E5%9B%9B%E8%B7%AF%E9%9B%86%E6%88%90%E9%80%9A%E4%BF%A1%E6%8E%A7%E5%88%B6%E5%99%A8%EF%BC%89%E3%80%82%3CBR%20%2F%3E-%20**360**%EF%BC%9A%E5%9E%8B%E5%8F%B7%20-%20%E8%AF%86%E5%88%AB%E7%B3%BB%E5%88%97%E4%B8%AD%E7%9A%84%E7%89%B9%E5%AE%9A%E8%8A%AF%E7%89%87%EF%BC%8C%E8%BF%99%E9%87%8C%E6%98%AF%20MC68360%EF%BC%8C%E4%B8%80%E4%B8%AA%E9%AB%98%E5%BA%A6%E9%9B%86%E6%88%90%E7%9A%84%20MPU%EF%BC%8C%E5%85%B7%E6%9C%89%E9%80%9A%E4%BF%A1%E5%92%8C%E6%8E%A7%E5%88%B6%E5%8A%9F%E8%83%BD%E3%80%82%3CBR%20%2F%3E-%20**C**%3A%E5%95%86%E7%94%A8%E6%B8%A9%E5%BA%A6%E8%8C%83%E5%9B%B4%20-%20%E8%A1%A8%E7%A4%BA%E6%B8%A9%E5%BA%A6%E7%AD%89%E7%BA%A7%EF%BC%8C%E9%80%9A%E5%B8%B8%E4%B8%BA%200%C2%B0C%20%E8%87%B3%20%2B70%C2%B0C%EF%BC%8C%E4%BD%86%E4%B9%9F%E5%8F%AF%E8%83%BD%E5%9B%A0%E5%90%8E%E7%BC%80%E4%B8%8D%E5%90%8C%E8%80%8C%E6%9C%89%E6%89%80%E5%8F%98%E5%8C%96%EF%BC%88%E8%AF%A6%E6%83%85%E8%A7%81%E4%B8%8B%E6%96%87%EF%BC%89%E3%80%82%3CBR%20%2F%3E-**A**%EF%BC%9A%E6%9E%B6%E6%9E%84%E6%88%96%E4%BB%A3%E7%A0%81%E5%8C%85%E5%8F%98%E4%BD%93%20%E2%80%94%20%E5%8F%AF%E8%83%BD%E4%BC%9A%E6%8C%87%E5%AE%9A%E7%89%B9%E5%AE%9A%E7%9A%84%E5%86%85%E9%83%A8%E6%9E%B6%E6%9E%84%E8%B0%83%E6%95%B4%E6%88%96%E4%BB%A3%E7%A0%81%E5%8C%85%E7%B1%BB%E5%9E%8B%EF%BC%8C%E5%B0%BD%E7%AE%A1%E6%91%A9%E6%89%98%E7%BD%97%E6%8B%89%E7%9A%84%E5%91%BD%E5%90%8D%E5%AF%B9%E5%85%B6%E5%AE%9A%E4%B9%89%E4%B8%8D%E5%A4%AA%E4%B8%80%E8%87%B4%E3%80%82%3CBR%20%2F%3E-%20**I**%3A%E5%B7%A5%E4%B8%9A%E6%B8%A9%E5%BA%A6%E8%8C%83%E5%9B%B4%20-%20%E8%A6%86%E7%9B%96%22C%22%20%E7%AD%89%E7%BA%A7%EF%BC%8C%E5%BB%BA%E8%AE%AE%E6%B8%A9%E5%BA%A6%E8%8C%83%E5%9B%B4%E4%B8%BA%20-40%C2%B0C%20%E8%87%B3%20%2B85%C2%B0C%EF%BC%8C%E7%AC%A6%E5%90%88%E5%B7%A5%E4%B8%9A%E5%BA%94%E7%94%A8%E8%A6%81%E6%B1%82%E3%80%82%3CBR%20%2F%3E-%20**25**%3A%E6%97%B6%E9%92%9F%E9%A2%91%E7%8E%87%20-%20%E4%BB%A3%E8%A1%A8%2025%20MHz%20%E5%B7%A5%E4%BD%9C%E9%A2%91%E7%8E%87%E3%80%82%3CBR%20%2F%3E-**L**%EF%BC%9A%E6%97%A0%E9%93%85%E6%88%96%E4%BD%8E%E5%8A%9F%E8%80%97%20%E2%80%94%20%E5%8F%AF%E8%83%BD%E8%A1%A8%E7%A4%BA%E6%97%A0%E9%93%85%E4%BB%A3%E7%A0%81%E5%8C%85%EF%BC%8C%E8%BD%AF%E4%BB%B6%E5%8C%85%EF%BC%88%E7%AC%A6%E5%90%88%20RoHS%20%E6%A0%87%E5%87%86%EF%BC%89%E6%88%96%E4%BD%8E%E5%8A%9F%E8%80%97%E5%8F%98%E4%BD%93%EF%BC%8C%E5%9C%A8%E5%90%8E%E7%BB%AD%E7%89%88%E6%9C%AC%E4%B8%AD%E5%BE%88%E5%B8%B8%E8%A7%81%E3%80%82%3C%2FP%3E%3CP%3E**%E5%85%B3%E9%94%AE%E6%A3%80%E6%9F%A5**%EF%BC%9A%E6%91%A9%E6%89%98%E7%BD%97%E6%8B%89%2F%E6%81%A9%E6%99%BA%E6%B5%A6%E6%95%B0%E6%8D%AE%E8%A1%A8%E4%B8%AD%E7%9A%84%E5%BB%BA%E7%AB%8B%E8%AF%B4%E6%98%8E%E9%80%9A%E5%B8%B8%E5%B0%86%E8%BF%99%E4%BA%9B%E4%BB%A3%E7%A0%81%E8%A7%86%E4%B8%BA%E6%A0%87%E5%87%86%E5%8C%96%E4%BB%A3%E7%A0%81%EF%BC%8C%E4%BD%86%22N%22%20%E5%92%8C%22A%22%20%E7%9A%84%E6%A8%A1%E7%B3%8A%E6%80%A7%E8%A1%A8%E6%98%8E%E7%94%9F%E4%BA%A7%E4%B8%AD%E5%AD%98%E5%9C%A8%E7%81%B5%E6%B4%BB%E6%80%A7%EF%BC%8C%E5%8F%AF%E8%83%BD%E5%AF%BC%E8%87%B4%E6%9C%AA%E5%AE%8C%E5%85%A8%E8%AE%B0%E5%BD%95%E7%9A%84%E5%8F%98%E5%8C%96%E3%80%82%22I%22%20%E5%B7%A5%E4%B8%9A%E7%BA%A7%E6%98%AF%E4%B8%80%E4%B8%AA%E5%85%B3%E9%94%AE%E7%9A%84%E5%8C%BA%E5%88%86%E5%9B%A0%E7%B4%A0%EF%BC%8C%E4%BD%86%E5%A6%82%E6%9E%9C%E4%B8%8D%E8%80%83%E8%99%91%E5%8F%AF%E9%9D%A0%E6%80%A7%E6%B5%8B%E8%AF%95%EF%BC%8C%E4%BB%85%E5%87%AD%E6%B8%A9%E5%BA%A6%E7%AD%89%E7%BA%A7%E5%B9%B6%E4%B8%8D%E8%83%BD%E5%AE%8C%E5%85%A8%E7%A1%AE%E5%AE%9A%E7%AD%89%E7%BA%A7%E3%80%82%3C%2FP%3E%3CP%3E%23%23%23%23%20%E5%B7%A5%E4%B8%9A%E5%AF%B9%E6%AF%94%E6%B6%88%E8%B4%B9%E7%BA%A7%3CBR%20%2F%3E%20%22%20MC68EN360CAI25L%22%20%E8%A2%AB%E5%BD%92%E7%B1%BB%E4%B8%BA**%E5%B7%A5%E4%B8%9A%E7%BA%A7%E8%8A%AF%E7%89%87**%EF%BC%8C%E5%9B%A0%E4%B8%BA%22I%22%20%E5%90%8E%E7%BC%80%E9%80%9A%E5%B8%B8%E8%A1%A8%E7%A4%BA%E6%89%A9%E5%B1%95%E7%9A%84%E6%B8%A9%E5%BA%A6%E8%8C%83%E5%9B%B4%EF%BC%88-40%C2%B0C%20%E8%87%B3%20%2B85%C2%B0C%EF%BC%89%E5%92%8C%E9%80%82%E5%90%88%E6%81%B6%E5%8A%A3%E7%8E%AF%E5%A2%83%EF%BC%88%E5%A6%82%E5%B7%A5%E5%8E%82%E8%87%AA%E5%8A%A8%E5%8C%96%E3%80%81%E7%94%B5%E4%BF%A1%EF%BC%89%E7%9A%84%E5%A2%9E%E5%BC%BA%E5%9E%8B%E5%8F%AF%E9%9D%A0%E6%80%A7%E6%B5%8B%E8%AF%95%E3%80%82%E8%BF%99%E4%B8%8E%E6%B6%88%E8%B4%B9%E7%BA%A7%E8%8A%AF%E7%89%87%E5%BD%A2%E6%88%90%E4%BA%86%E9%B2%9C%E6%98%8E%E5%AF%B9%E6%AF%94%EF%BC%8C%E6%B6%88%E8%B4%B9%E7%BA%A7%E8%8A%AF%E7%89%87%E7%9A%84%E5%B7%A5%E4%BD%9C%E6%B8%A9%E5%BA%A6%E9%80%9A%E5%B8%B8%E9%99%90%E5%88%B6%E5%9C%A8%200%C2%B0C%20%E8%87%B3%20%2B70%C2%B0C%EF%BC%8C%E5%AF%B9%E6%8C%AF%E5%8A%A8%E3%80%81%E6%B9%BF%E5%BA%A6%E6%88%96%E5%B7%A5%E4%B8%9A%E7%8E%AF%E5%A2%83%E4%B8%8B%E7%9A%84%E9%95%BF%E6%9C%9F%E8%BF%90%E8%A1%8C%E7%BC%BA%E4%B9%8F%E4%B8%A5%E6%A0%BC%E7%9A%84%E8%AE%A4%E8%AF%81%E8%A6%81%E6%B1%82%E3%80%82%3C%2FP%3E%3CP%3E-**%E8%AF%81%E6%8D%AE**%EF%BC%9AMC68360%20%E7%B3%BB%E5%88%97%EF%BC%8C%E5%8C%85%E6%8B%AC%20EN360%20%E5%8F%98%E4%BD%93%EF%BC%8C%E4%B8%93%E4%B8%BA%E5%B5%8C%E5%85%A5%E5%BC%8F%E9%80%9A%E4%BF%A1%E5%BA%94%E7%94%A8%EF%BC%88%E4%BE%8B%E5%A6%82%E8%B7%AF%E7%94%B1%E5%99%A8%E3%80%81%E5%B7%A5%E4%B8%9A%E6%8E%A7%E5%88%B6%E5%99%A8%EF%BC%89%E8%80%8C%E8%AE%BE%E8%AE%A1%EF%BC%8C%E5%9C%A8%E8%BF%99%E4%BA%9B%E5%BA%94%E7%94%A8%E4%B8%AD%EF%BC%8C%E5%B7%A5%E4%B8%9A%E7%BA%A7%E5%8F%AF%E9%9D%A0%E6%80%A7%E8%87%B3%E5%85%B3%E9%87%8D%E8%A6%81%E3%80%82%E5%9C%A8%E8%AF%A5%E7%B3%BB%E5%88%97%E4%B8%AD%EF%BC%8C%E6%B6%88%E8%B4%B9%E7%BA%A7%E5%8F%98%E4%BD%93%EF%BC%88%E5%A6%82%E4%B8%8D%E5%90%AB%22I%22%20%EF%BC%89%E8%BE%83%E5%B0%91%E8%A7%81%E3%80%82%3CBR%20%2F%3E-%20**%E6%89%B9%E5%88%A4%E6%80%A7%E8%A7%82%E7%82%B9**%EF%BC%9A%22%20%E5%B7%A5%E4%B8%9A%E7%BA%A7%20%22%20%E7%9A%84%E5%8F%99%E8%BF%B0%E5%A6%82%E6%9E%9C%E4%B8%8D%E4%B8%8E%E5%85%B7%E4%BD%93%E7%9A%84%E5%BA%94%E7%94%A8%E7%AC%94%E8%AE%B0%E6%90%AD%E9%85%8D%E4%BD%BF%E7%94%A8%EF%BC%8C%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%A4%B8%E5%A4%A7%E8%80%90%E4%B9%85%E6%80%A7%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%9F%90%E4%BA%9B%E5%B7%A5%E4%B8%9A%E8%8A%AF%E7%89%87%E5%9C%A8%E6%B2%A1%E6%9C%89%E9%80%82%E5%BD%93%E7%9A%84%E8%AE%BE%E8%AE%A1%E6%94%AF%E6%8C%81%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E5%9C%A8%E6%9E%81%E7%AB%AF%E6%9D%A1%E4%BB%B6%E4%B8%8B%E4%BB%8D%E7%84%B6%E4%BC%9A%E5%A4%B1%E6%95%88%E3%80%82%E8%BF%99%E7%A7%8D%E7%89%B9%E5%AE%9A%E5%9E%8B%E5%8F%B7%E7%BC%BA%E4%B9%8F%E6%B6%88%E8%B4%B9%E7%BA%A7%E7%9A%84%E5%90%8C%E7%B1%BB%E4%BA%A7%E5%93%81%EF%BC%8C%E8%BF%99%E8%A1%A8%E6%98%8E%E5%B8%82%E5%9C%BA%E7%9A%84%E9%87%8D%E7%82%B9%E6%98%AF%E5%B7%A5%E4%B8%9A%E7%94%A8%E9%80%94%EF%BC%8C%E4%BD%86%E8%BF%99%E5%8F%AF%E8%83%BD%E5%8F%8D%E6%98%A0%E4%BA%86%E9%99%88%E6%97%A7%E8%80%8C%E9%9D%9E%E6%84%8F%E5%9B%BE%E3%80%82%3C%2FP%3E%3CP%3E%23%23%23%20MC68360CRC25L%20%E5%92%8C%20MC68EN360CAI25L%20%E4%B9%8B%E9%97%B4%E7%9A%84%E5%8F%AF%E6%9B%BF%E6%8D%A2%E6%80%A7%3CBR%20%2F%3E%20%22%20MC68360CRC25L%22%20%E6%98%AF%E5%BD%93%E5%89%8D%E5%8F%AF%E7%94%A8%E7%9A%84%E5%8F%98%E4%BD%93%EF%BC%8C%E8%80%8C%22MC68EN360CAI25L%22%20%E5%B7%B2%E5%81%9C%E4%BA%A7%E3%80%82%E8%AE%A9%E6%88%91%E4%BB%AC%E6%9D%A5%E8%AF%84%E4%BC%B0%E4%B8%80%E4%B8%8B%E4%BB%96%E4%BB%AC%E7%9A%84%E5%8F%AF%E6%9B%BF%E4%BB%A3%E6%80%A7%EF%BC%9A%3C%2FP%3E%3CP%3E-**%E6%AF%94%E8%BE%83**%EF%BC%9A%3CBR%20%2F%3E-**MC68EN360CAI25L**%EF%BC%9A%E5%A2%9E%E5%BC%BA%E5%9E%8B%20QUICC%20%E9%87%87%E7%94%A8%E5%B7%A5%E4%B8%9A%E7%BA%A7%EF%BC%88-40%C2%B0C%20%E8%87%B3%20%2B85%C2%B0C%EF%BC%89%EF%BC%8C25%20MHz%EF%BC%8C%E5%8F%AF%E8%83%BD%E5%85%B7%E6%9C%89%E5%85%B6%E4%BB%96%E5%8A%9F%E8%83%BD%EF%BC%88%E6%A0%B9%E6%8D%AE%20%22%20N%20%22%EF%BC%89%EF%BC%8C%E4%BB%A3%E7%A0%81%E5%8C%85%E4%B8%8E%2068360%20%E7%B3%BB%E5%88%97%EF%BC%88%E4%BE%8B%E5%A6%82%20240%20%E9%92%88%20PQFP%EF%BC%89%E5%85%BC%E5%AE%B9%E3%80%82%3CBR%20%2F%3E-**MC68360CRC25L**%EF%BC%9A%E6%A0%87%E5%87%86%20QUICC%EF%BC%8C%E5%95%86%E7%94%A8%E7%BA%A7%EF%BC%880%C2%B0C%20%E8%87%B3%20%2B70%C2%B0C%EF%BC%89%EF%BC%8C25%20MHz%EF%BC%8C%E5%90%8C%E6%A0%B7%E9%87%87%E7%94%A8%20240%20%E9%92%88%20PQFP%E3%80%82%22C%22%20%E8%A1%A8%E7%A4%BA%E5%95%86%E4%B8%9A%E6%B8%A9%E5%BA%A6%EF%BC%8C%22RC%22%20%E5%8F%AF%E8%83%BD%E8%A1%A8%E7%A4%BA%E4%BF%AE%E6%94%B9%E5%90%8E%E7%9A%84%E9%85%8D%E7%BD%AE%E6%88%96%E6%88%90%E6%9C%AC%E4%BC%98%E5%8C%96%E7%89%88%E6%9C%AC%E3%80%82%3C%2FP%3E%3CP%3E-**%E5%BC%95%E8%84%9A%E5%92%8C%E5%8A%9F%E8%83%BD%E5%85%BC%E5%AE%B9%E6%80%A7**%EF%BC%9A%3CBR%20%2F%3E-%E4%B8%A4%E8%80%85%E5%85%B1%E4%BA%AB%20MC68360%20%E5%86%85%E6%A0%B8%EF%BC%8C%E8%BF%99%E6%98%AF%E4%B8%80%E6%AC%BE%E5%B8%A6%E6%9C%89%E9%9B%86%E6%88%90%E9%80%9A%E4%BF%A1%E5%A4%84%E7%90%86%E5%99%A8%EF%BC%88%E4%BE%8B%E5%A6%82%20UART%E3%80%81HDLC%E3%80%81%E4%BB%A5%E5%A4%AA%E7%BD%91%EF%BC%89%E7%9A%84%2032%20%E4%BD%8D%20MPU%EF%BC%8C%E8%BF%99%E8%A1%A8%E6%98%8E%E5%BC%95%E8%84%9A%E5%B8%83%E5%B1%80%EF%BC%88240%20%E4%B8%AA%E5%BC%95%E8%84%9A%EF%BC%89%E5%92%8C%E5%9F%BA%E6%9C%AC%E5%8A%9F%E8%83%BD%E7%9B%B8%E4%BC%BC%E3%80%82%3CBR%20%2F%3E-MC68EN360CAI25L%20%E4%B8%AD%E7%9A%84%20%22%20EN%20%22%20%E6%84%8F%E5%91%B3%E7%9D%80%E5%A2%9E%E5%BC%BA%E5%8A%9F%E8%83%BD%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8C%E9%A2%9D%E5%A4%96%E7%9A%84%E9%80%9A%E4%BF%A1%E4%BF%A1%E9%81%93%E6%88%96%E6%80%A7%E8%83%BD%E6%8F%90%E5%8D%87%EF%BC%89%EF%BC%8C%E8%BF%99%E5%8F%AF%E8%83%BD%E4%B8%8D%E5%9C%A8%20MC68360CRC25L%20%E4%B8%AD%EF%BC%8C%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%BD%B1%E5%93%8D%E4%B8%B2%E8%A1%8C%E7%AB%AF%E5%8F%A3%E6%95%B0%E6%88%96%E6%80%BB%E7%BA%BF%E9%80%9F%E5%BA%A6%E7%AD%89%E5%8A%9F%E8%83%BD%E3%80%82%3CBR%20%2F%3E-%20%E6%B8%A9%E5%BA%A6%E8%8C%83%E5%9B%B4%E7%9A%84%E5%B7%AE%E5%BC%82%EF%BC%88-40%C2%B0C%20%E8%87%B3%20%2B85%C2%B0C%20%E4%B8%8E%200%C2%B0C%20%E8%87%B3%20%2B70%C2%B0C%EF%BC%89%E6%84%8F%E5%91%B3%E7%9D%80%20MC68360CRC25L%20%E5%9C%A8%E5%B7%A5%E4%B8%9A%E6%9D%A1%E4%BB%B6%E4%B8%8B%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%87%BA%E7%8E%B0%E6%95%85%E9%9A%9C%EF%BC%8C%E4%BB%8E%E8%80%8C%E9%99%90%E5%88%B6%E4%BA%86%E5%85%B6%E7%9B%B4%E6%8E%A5%E6%9B%BF%E6%8D%A2%E6%80%A7%E3%80%82%3C%2FP%3E%3CP%3E-%20%E5%8F%AF%E6%9B%BF%E6%8D%A2%E6%80%A7%E8%AF%84%E4%BC%B0**%EF%BC%9A%3CBR%20%2F%3E-%20**%E9%83%A8%E5%88%86%E5%8F%AF%E6%9B%BF%E6%8D%A2%E6%80%A7**%EF%BC%9AMC68360CRC25L%20%E5%8F%AF%E5%9C%A8%E5%B7%A5%E4%B8%9A%E6%B8%A9%E5%BA%A6%E8%8C%83%E5%9B%B4%E5%92%8C%E5%A2%9E%E5%BC%BA%E5%8A%9F%E8%83%BD%E5%B9%B6%E4%B8%8D%E9%87%8D%E8%A6%81%E7%9A%84%E5%BA%94%E7%94%A8%E4%B8%AD%E6%9B%BF%E4%BB%A3%20MC68EN360CAI25L%EF%BC%8C%E5%89%8D%E6%8F%90%E6%98%AF%E9%92%88%E5%AF%B9%E4%BB%BB%E4%BD%95%E5%8A%9F%E8%83%BD%E5%B7%AE%E5%BC%82%EF%BC%88%E5%A6%82%E7%BC%BA%E5%B0%91%22N%22%20%E5%8A%9F%E8%83%BD%EF%BC%89%E5%AF%B9%E5%9B%BA%E4%BB%B6%E8%BF%9B%E8%A1%8C%E8%B0%83%E6%95%B4%E3%80%82%E9%92%88%E8%84%9A%E5%85%BC%E5%AE%B9%E6%80%A7%E5%85%81%E8%AE%B8%E7%89%A9%E7%90%86%E6%9B%BF%E4%BB%A3%EF%BC%8C%E4%BD%86%E9%9C%80%E8%A6%81%E8%BF%9B%E8%A1%8C%E7%94%B5%E6%B0%94%E5%92%8C%E7%83%AD%E9%AA%8C%E8%AF%81%E3%80%82%3CBR%20%2F%3E-%20%E9%99%90%E5%88%B6**%EF%BC%9A%E5%95%86%E4%B8%9A%E7%BA%A7%E9%99%90%E5%88%B6%E4%BA%86%E5%9C%A8%E5%B7%A5%E4%B8%9A%E7%8E%AF%E5%A2%83%E4%B8%AD%E7%9A%84%E4%BD%BF%E7%94%A8%EF%BC%8C%E8%80%8C%22EN%22%20%E5%8F%98%E4%BD%93%E4%B8%AD%E6%9C%AA%E8%AE%B0%E8%BD%BD%E7%9A%84%E5%A2%9E%E5%BC%BA%E5%8A%9F%E8%83%BD%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%AF%BC%E8%87%B4%E6%80%A7%E8%83%BD%E5%B7%AE%E8%B7%9D%E3%80%82%E5%A6%82%E6%9E%9C%E6%B2%A1%E6%9C%89%E5%85%B7%E4%BD%93%E7%9A%84%E4%BA%A4%E5%8F%89%E5%8F%82%E8%80%83%E6%95%B0%E6%8D%AE%EF%BC%8C68360%E7%B3%BB%E5%88%97%E4%B8%AD%E5%90%8E%E5%90%91%E5%85%BC%E5%AE%B9%E6%80%A7%E8%AF%B4%E6%B3%95%E6%98%AF%E5%80%BC%E5%BE%97%E6%80%80%E7%96%91%E7%9A%84%E3%80%82%3CBR%20%2F%3E-**%E6%89%B9%E5%88%A4%E6%80%A7%E8%A7%82%E7%82%B9**%EF%BC%9A%E6%81%A9%E6%99%BA%E6%B5%A6%E5%AF%B9%E4%BC%A0%E7%BB%9F%E6%94%AF%E6%8C%81%E7%9A%84%E5%85%B3%E6%B3%A8%E5%8F%AF%E8%83%BD%E4%BC%9A%E6%B7%A1%E5%8C%96%E9%87%8D%E6%96%B0%E9%AA%8C%E8%AF%81%E7%9A%84%E9%9C%80%E6%B1%82%EF%BC%8C%E5%9B%A0%E4%B8%BA%20%22%20CRC%20%22%20%E5%8F%98%E4%BD%93%E7%9A%84%E5%BE%AE%E5%A6%99%E8%8A%AF%E7%89%87%E4%BF%AE%E8%AE%A2%E6%88%96%E5%8A%9F%E8%83%BD%E5%89%8A%E5%87%8F%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%B8%A6%E6%9D%A5%E5%85%AC%E5%BC%80%E6%95%B0%E6%8D%AE%E8%A1%A8%E4%B8%AD%E6%9C%AA%E6%B6%89%E5%8F%8A%E7%9A%84%E9%A3%8E%E9%99%A9%E3%80%82%3C%2FP%3E%3CP%3E-**%E4%BE%9B%E8%B4%A7%E6%83%85%E5%86%B5%E5%92%8C%E6%9B%BF%E4%BB%A3%E5%93%81**%EF%BC%9AMC68360CRC25L%20%E7%9A%84%E4%BE%9B%E8%B4%A7%E6%83%85%E5%86%B5%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8C%E9%80%9A%E8%BF%87%20Veswin%20%E6%88%96%20Jotrin%20%E7%AD%89%E4%BB%A3%E7%90%86%E5%95%86%EF%BC%89%E8%A1%A8%E6%98%8E%E5%AE%83%E6%98%AF%E9%87%8D%E5%94%AE%E6%88%96%E5%BA%93%E5%AD%98%E5%95%86%E5%93%81%EF%BC%8C%E4%BD%86%E5%85%B6%E5%95%86%E4%B8%9A%E7%AD%89%E7%BA%A7%E9%99%90%E5%88%B6%E4%BA%86%E8%8C%83%E5%9B%B4%E3%80%82%E7%94%B1%E4%BA%8E%E4%BB%A3%E7%A0%81%E5%8C%85%EF%BC%8C%E8%BD%AF%E4%BB%B6%E5%8C%85%E5%92%8C%E6%9E%B6%E6%9E%84%E7%9A%84%E5%8F%98%E5%8C%96%EF%BC%8CMC68360EM25L%EF%BC%88%E5%A2%9E%E5%BC%BA%E5%9E%8B%E3%80%81%E5%B7%A5%E4%B8%9A%E7%BA%A7%EF%BC%89%E6%88%96%E6%9B%B4%E6%96%B0%E7%9A%84%E6%81%A9%E6%99%BA%E6%B5%A6%20i.MX%20RT%20%E7%B3%BB%E5%88%97%E7%AD%89%E6%9B%BF%E4%BB%A3%E4%BA%A7%E5%93%81%E5%8F%AF%E8%83%BD%E9%9C%80%E8%A6%81%E9%87%8D%E6%96%B0%E8%AE%BE%E8%AE%A1%E3%80%82%3C%2FP%3E%3CP%3E%23%23%23%23%20%E5%BB%BA%E8%AE%AE%3CBR%20%2F%3E-%20**%E5%AD%97%E6%AF%8D%E5%90%AB%E4%B9%89**%EF%BC%9A%E9%80%9A%E8%BF%87%E6%9F%A5%E9%98%85%20MC68EN360CAI25L%20%E6%95%B0%E6%8D%AE%E8%A1%A8%EF%BC%88%E9%80%9A%E8%BF%87%20NXP%20%E6%94%AF%E6%8C%81%E6%88%96%E5%AD%98%E6%A1%A3%EF%BC%89%E7%A1%AE%E8%AE%A4%22N%22%20%E5%92%8C%22A%22%20%E7%9A%84%E5%85%B7%E4%BD%93%E5%86%85%E5%AE%B9%EF%BC%8C%E4%BB%A5%E4%BA%86%E8%A7%A3%E5%A2%9E%E5%BC%BA%E5%8A%9F%E8%83%BD%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%85%AC%E5%BC%80%E6%95%B0%E6%8D%AE%E6%98%AF%E6%A8%A1%E7%B3%8A%E7%9A%84%E3%80%82%3CBR%20%2F%3E-%20**%E7%AD%89%E7%BA%A7%E7%A1%AE%E8%AE%A4**%EF%BC%9A%E6%A0%B9%E6%8D%AE%22I%22%20%E5%90%8E%E7%BC%80%EF%BC%8C%E5%8F%AF%E5%B0%86%E5%85%B6%E8%A7%86%E4%B8%BA%E5%B7%A5%E4%B8%9A%E7%BA%A7%E4%BA%A7%E5%93%81%EF%BC%8C%E4%BD%86%E9%9C%80%E6%A0%B9%E6%8D%AE%20-40%C2%B0C%20%E8%87%B3%20%2B85%C2%B0C%20%E7%9A%84%E8%A7%84%E6%A0%BC%E8%A6%81%E6%B1%82%EF%BC%8C%E7%A1%AE%E8%AE%A4%E6%82%A8%E7%9A%84%E5%BA%94%E7%94%A8%E5%AF%B9%E6%95%A3%E7%83%AD%E5%92%8C%E5%8F%AF%E9%9D%A0%E6%80%A7%E7%9A%84%E9%9C%80%E6%B1%82%E3%80%82%3CBR%20%2F%3E-%20**%E5%8F%AF%E6%9B%BF%E6%8D%A2%E6%80%A7**%EF%BC%9A%E5%B0%86%20MC68360CRC25L%20%E4%BD%9C%E4%B8%BA%E5%8E%9F%E5%9E%8B%E4%B8%AD%E7%9A%84%E6%9B%BF%E4%BB%A3%E5%93%81%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%EF%BC%8C%E9%92%88%E5%AF%B9%E6%BD%9C%E5%9C%A8%E7%9A%84%E5%8A%9F%E8%83%BD%E6%8D%9F%E5%A4%B1%E8%B0%83%E6%95%B4%E5%9B%BA%E4%BB%B6%EF%BC%8C%E5%B9%B6%E7%9B%91%E6%8E%A7%E6%9E%81%E7%AB%AF%E6%B8%A9%E5%BA%A6%E4%B8%8B%E7%9A%84%E6%80%A7%E8%83%BD%E3%80%82%E8%AF%B7%E8%81%94%E7%B3%BB%E6%81%A9%E6%99%BA%E6%B5%A6%E6%94%AF%E6%8C%81%E9%83%A8%E9%97%A8%EF%BC%88%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fsupport%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ewww.nxp.com%2Fsupport%EF%BC%89%E5%B9%B6%E6%8F%90%E4%BE%9B%3C%2FA%3E%E4%B8%A4%E4%B8%AA%E9%83%A8%E4%BB%B6%E5%8F%B7%EF%BC%8C%E7%B4%A2%E5%8F%96%E4%BA%A4%E5%8F%89%E5%8F%82%E8%80%83%E6%88%96%E8%BF%81%E7%A7%BB%E6%8C%87%E5%8D%97%E3%80%82%3CBR%20%2F%3E-%20%E4%B8%8B%E4%B8%80%E6%AD%A5**%EF%BC%9A%E5%A6%82%E6%9E%9C%E5%BF%85%E9%A1%BB%E4%BD%BF%E7%94%A8%E5%B7%A5%E4%B8%9A%E7%BA%A7%20MCU%EF%BC%8C%E5%8F%AF%E4%BB%8E%E7%BB%8F%E7%BA%AA%E5%95%86%EF%BC%88%E5%A6%82%E7%BB%8F%E7%BA%AA%E5%95%86%E8%AE%BA%E5%9D%9B%EF%BC%89%E5%A4%84%E5%AF%BB%E6%89%BE%E5%89%A9%E4%BD%99%E7%9A%84%20MC68EN360CAI25L%20%E5%BA%93%E5%AD%98%EF%BC%8C%E6%88%96%E8%80%83%E8%99%91%E4%BD%BF%E7%94%A8%E7%8E%B0%E4%BB%A3%E6%81%A9%E6%99%BA%E6%B5%A6%20MCU%20%E9%87%8D%E6%96%B0%E8%AE%BE%E8%AE%A1%EF%BC%8C%E5%B9%B6%E6%89%BF%E6%8B%85%E5%BC%80%E5%8F%91%E6%88%90%E6%9C%AC%E3%80%82%3C%2FP%3E%3CP%3E%23%23%23%20%E7%BB%93%E8%AE%BA%20%3CBR%20%2F%3E%20%22%20MC68EN360CAI25L%20%22%20%E5%AD%97%E6%AF%8D%E8%A1%A8%E7%A4%BA%E6%91%A9%E6%89%98%E7%BD%97%E6%8B%89%2068000%20%E7%B3%BB%E5%88%97%E5%A2%9E%E5%BC%BA%E5%9E%8B%20QUICC%20%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%EF%BC%8C%E9%87%87%E7%94%A8%E5%B7%A5%E4%B8%9A%E7%BA%A7%EF%BC%8C%E6%97%B6%E9%92%9F%E9%A2%91%E7%8E%87%E4%B8%BA%2025%20MHz%EF%BC%8C%E9%87%87%E7%94%A8%E6%97%A0%E9%93%85%E4%BB%A3%E7%A0%81%E5%8C%85%EF%BC%8C%E8%BD%AF%E4%BB%B6%E5%8C%85%E3%80%82%E5%AE%83%E6%98%AF%E5%B7%A5%E4%B8%9A%E7%BA%A7%E7%9A%84%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E6%B6%88%E8%B4%B9%E7%BA%A7%E7%9A%84%E3%80%82%E7%94%B1%E4%BA%8E%E5%BC%95%E8%84%9A%E5%85%BC%E5%AE%B9%EF%BC%8CMC68360CRC25L%20%E5%8F%AF%E4%BB%A5%E9%83%A8%E5%88%86%E6%9B%BF%E4%BB%A3%EF%BC%8C%E4%BD%86%E7%BC%BA%E4%B9%8F%E5%B7%A5%E4%B8%9A%E6%B8%A9%E5%BA%A6%E8%8C%83%E5%9B%B4%E5%92%8C%E5%8F%AF%E8%83%BD%E7%9A%84%E5%A2%9E%E5%BC%BA%E5%8A%9F%E8%83%BD%EF%BC%8C%E9%9C%80%E8%A6%81%E9%AA%8C%E8%AF%81%E3%80%82%E5%BB%BA%E7%AB%8B%E8%BD%BB%E6%9D%BE%E6%9B%BF%E4%BB%A3%E7%9A%84%E8%AF%B4%E6%B3%95%E6%98%AF%E4%B9%90%E8%A7%82%E7%9A%84%EF%BC%8C%E9%9C%80%E8%A6%81%E8%BF%9B%E8%A1%8C%E5%BD%BB%E5%BA%95%E7%9A%84%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E8%83%BD%E6%8F%90%E4%BE%9B%E6%82%A8%E7%9A%84%E5%BA%94%E7%94%A8%E7%BB%86%E8%8A%82%EF%BC%88%E5%A6%82%E6%B8%A9%E5%BA%A6%E8%8C%83%E5%9B%B4%E3%80%81%E6%89%80%E9%9C%80%E5%8A%9F%E8%83%BD%EF%BC%89%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E8%BF%9B%E4%B8%80%E6%AD%A5%E6%94%B9%E8%BF%9B%E3%80%82%E7%A5%9D%E6%82%A8%E7%9A%84%E9%A1%B9%E7%9B%AE%E5%8F%96%E5%BE%97%E6%88%90%E5%8A%9F%EF%BC%81%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Motorola%20MC68EN360CAI25L%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E9%81%97%E6%86%BE%E7%9A%84%E6%98%AF%EF%BC%8C%E7%9B%AE%E5%89%8D%E8%BF%98%E6%B2%A1%E6%9C%89%E4%B8%8E%20MC68EN360CAI25L%20%E8%8A%AF%E7%89%87%E5%85%BC%E5%AE%B9%E7%9A%84%20MCU%20%E6%96%B0%E4%BA%A7%E5%93%81%E3%80%82%E5%90%8C%E6%97%B6%EF%BC%8C%E6%81%A9%E6%99%BA%E6%B5%A6%E5%9F%BA%E4%BA%8EARM%20Cortex-M%E7%9A%84%E6%96%B0%E6%AC%BE%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E4%BA%A7%E5%93%81%E5%85%B7%E6%9C%89%E5%AE%8C%E6%95%B4%E7%9A%84%E7%94%9F%E6%80%81%E7%B3%BB%E7%BB%9F%EF%BC%88%E8%BD%AF%E4%BB%B6%2F%E7%A1%AC%E4%BB%B6%EF%BC%89%EF%BC%8C%E5%8F%AF%E7%A1%AE%E4%BF%9D%E8%BD%BB%E6%9D%BE%E5%BC%80%E5%8F%91%E5%AE%A2%E6%88%B7%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%E4%BB%8E%E6%8A%95%E8%B5%84%E5%9B%9E%E6%8A%A5%E7%8E%87%EF%BC%88ROI%EF%BC%89%E7%9A%84%E8%A7%92%E5%BA%A6%E6%9D%A5%E7%9C%8B%EF%BC%8C%E4%B8%8E%E5%85%B6%E4%BF%AE%E8%A1%A5%E6%97%A7%E7%9A%84%E4%BA%A7%E5%93%81%E7%B3%BB%E7%BB%9F%EF%BC%8C%E4%B8%8D%E5%A6%82%E8%AE%BE%E8%AE%A1%E4%B8%80%E4%B8%AA%E6%96%B0%E7%9A%84%E5%B9%B3%E5%8F%B0%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136939%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Motorola%20MC68EN360CAI25L%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136939%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%9C%89%E4%B8%80%E7%A7%8D%E6%97%A7%E4%BA%A7%E5%93%81%EF%BC%8C%E5%85%B6%20MCU%20%E5%9E%8B%E5%8F%B7%E4%B8%BA%20MC68EN360CAI25L%EF%BC%8C%E5%8F%AA%E6%9C%89%E5%8F%AF%E6%89%A7%E8%A1%8C%E6%96%87%E4%BB%B6%EF%BC%8C%E6%B2%A1%E6%9C%89%E6%BA%90%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%3CP%3E%E8%80%8C%E4%BD%9C%E4%B8%BA%E5%85%AC%E5%8F%B8%E7%9A%84%E6%96%B0%E4%BA%BA%EF%BC%8C%E9%99%A4%E4%BA%86%E6%88%91%E4%B9%8B%E5%A4%96%EF%BC%8C%E6%B2%A1%E6%9C%89%E4%BA%BA%E7%9F%A5%E9%81%93%E6%97%A7%E4%BA%A7%E5%93%81%E4%BD%BF%E7%94%A8%20MC68EN360CAI25L%20%E5%AE%9E%E7%8E%B0%E4%BA%86%E5%93%AA%E4%BA%9B%E5%85%B7%E4%BD%93%E5%8A%9F%E8%83%BD%E5%92%8C%E9%80%BB%E8%BE%91%E3%80%82%E5%A6%82%E6%9E%9C%E9%87%87%E7%94%A8%E6%96%B0%E7%9A%84%20MCU%EF%BC%8C%E4%B9%9F%E8%AE%B8%E4%BB%8E%E5%A4%B4%E5%BC%80%E5%A7%8B%E5%BC%80%E5%8F%91%E5%B0%86%E6%98%AF%E4%B8%80%E9%A1%B9%E8%89%B0%E5%B7%A8%E7%9A%84%E4%BB%BB%E5%8A%A1%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%89%E6%B2%A1%E6%9C%89%E4%B8%8E%20MC68EN360%20%E5%85%BC%E5%AE%B9%E7%9A%84%E6%96%B0%20MCU%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136928%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Motorola%20MC68EN360CAI25L%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136928%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E6%9B%B4%E5%A4%9A%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%E8%AF%B7%E5%8F%82%E8%80%83%E4%B8%8B%E5%9B%BE%E3%80%82%E8%BF%99%E4%B8%A4%E7%A7%8D%E8%8A%AF%E7%89%87%E9%83%BD%E6%98%AF%E6%B6%88%E8%B4%B9%E7%BA%A7%E7%9A%84%E3%80%82%3C%2FP%3E%0A%3CP%3EAI%20%E4%BB%A3%E8%A1%A8%E5%8C%85%E8%A3%85%E7%B1%BB%E5%9E%8B%EF%BC%9BL%20%E4%BB%A3%E8%A1%A8%E4%BF%AE%E8%AE%A2%E7%89%88%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Hui_Ma_0-1753062244410.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Hui_Ma_0-1753062244410.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348356i74B0E378DD43403A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Hui_Ma_0-1753062244410.png%22%20alt%3D%22Hui_Ma_0-1753062244410.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E5%A6%82%E6%9E%9C%E4%B8%8D%E9%9C%80%E8%A6%81%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%A8%A1%E5%9D%97%EF%BC%8C%E8%BF%99%E6%A0%B7%E5%B0%B1%E5%8F%AF%E4%BB%A5%E4%BA%86%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%8F%AA%E6%98%AF%E5%A5%BD%E5%A5%87%EF%BC%8C%E4%B8%BA%E4%BB%80%E4%B9%88%E8%BF%98%E8%A6%81%E8%80%83%E8%99%91%E4%BD%BF%E7%94%A8%E8%BF%99%E4%B9%88%E6%97%A7%E7%9A%84%E4%BA%A7%E5%93%81%20%3CSPAN%3EMC68360CRC25L%20%E4%BD%9C%E4%B8%BA%E6%9B%BF%E4%BB%A3%E5%93%81%EF%BC%9F%E4%B8%BA%E4%BB%80%E4%B9%88%E4%B8%8D%E4%BD%BF%E7%94%A8%E5%85%B7%E6%9C%89%E6%9B%B4%E5%BC%BA%E5%A4%A7%E5%8A%9F%E8%83%BD%E7%9A%84%20Arm%20Cortex%20M%20%E7%B3%BB%E5%88%97%20MCU%20%E6%96%B0%E4%BA%A7%E5%93%81%E7%B3%BB%E5%88%97%3C%2FSPAN%3E%EF%BC%9F%3CSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136912%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Motorola%20MC68EN360CAI25L%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136912%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%8F%91%E7%8E%B0%E6%82%A8%E5%9C%A8%2232%20%E4%BD%8D%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E5%92%8C%E5%A4%84%E7%90%86%E5%99%A8%202006%20%E5%B9%B4%E7%AC%AC%202%20%E5%AD%A3%E5%BA%A6%20SG1001Q22006%20Rev%200%22%20%E4%B8%AD%E5%8F%91%E5%B8%83%E7%9A%84%E8%BF%99%E5%BC%A0%E5%9B%BE%E7%89%87%EF%BC%8C%E8%BF%99%E6%98%AF%E5%AF%B9%E4%BA%A7%E5%93%81%22MC68331%22%2C%22MC68332%22%2C%22MC68336%22%2C%22MC68376%22%2C%20%E8%AF%A5%E4%BA%A7%E5%93%81%E7%BC%96%E5%8F%B7%E7%B3%BB%E7%BB%9F%E8%A7%84%E5%88%99%E6%98%AF%E5%90%A6%E9%80%82%E7%94%A8%E4%BA%8E%22MC68EN360CAI25L%22%20%EF%BC%9F%3C%2FP%3E%3CP%3E%22MC68EN360CAI25L%22%20%E6%98%AF%E5%B7%A5%E4%B8%9A%E7%BA%A7%E8%8A%AF%E7%89%87%E5%90%97%EF%BC%9F%22EN%22%20%E5%92%8C%22I%22%20%E7%9A%84%E5%90%AB%E4%B9%89%E5%9C%A8%E8%BF%99%E5%B9%85%E5%9B%BE%E4%B8%AD%E6%B2%A1%E6%9C%89%E6%98%8E%E7%A1%AE%E8%A1%A8%E7%A4%BA%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%E6%B2%A1%E6%9C%89%E4%BB%A5%E5%A4%AA%E7%BD%91%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%8E%20MC68360CRC25L%20%E5%88%B0%20MC68EN360CAI25L%20%E6%B2%A1%E6%9C%89%E7%9B%B4%E6%8E%A5%E7%9A%84%E6%9B%BF%E4%BB%A3%E5%93%81%EF%BC%88%E5%BC%95%E8%84%9A%E9%97%B4%E5%85%BC%E5%AE%B9%E6%88%96%E6%B2%A1%E6%9C%89%E7%A1%AC%E4%BB%B6%2F%E8%BD%AF%E4%BB%B6%E6%9B%B4%E6%94%B9%EF%BC%89%EF%BC%8C%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E8%AE%A1%E5%88%92%E5%88%B6%E4%BD%9C%E4%B8%80%E4%B8%AA%20PCB%20%E6%9D%A5%E5%B0%86%20MC68360CRC25L%20%E4%BB%A3%E7%A0%81%E5%8C%85%E8%BD%AC%E6%8D%A2%E4%B8%BA%E9%80%82%E5%90%88%E7%84%8A%E6%8E%A5%20MC68EN360CAI25L%20%E7%9A%84%20LQFP240%20%E5%B0%81%E8%A3%85%EF%BC%8C%E8%BF%99%E8%A1%8C%E5%BE%97%E9%80%9A%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136905%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Motorola%20MC68EN360CAI25L%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136905%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E6%9C%89%E5%85%B3%2068K%20%E4%BA%A7%E5%93%81%E5%91%BD%E5%90%8D%E8%A7%84%E5%88%99%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%E4%B8%8B%E5%9B%BE%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Hui_Ma_0-1753056932442.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Hui_Ma_0-1753056932442.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348347iA9237C1374F5ECBF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Hui_Ma_0-1753056932442.png%22%20alt%3D%22Hui_Ma_0-1753056932442.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EMC68EN360CAI25L%20%E7%9A%84%E5%B7%A5%E4%BD%9C%E6%B8%A9%E5%BA%A6%E4%B8%BA%20%22C%20%3D%20-40%E2%84%83%20%E8%87%B3%2085%E2%84%83%22%EF%BC%8C%E5%B1%9E%E4%BA%8E%E6%B6%88%E8%B4%B9%E7%BA%A7%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%85%B3%E4%BA%8E%20MC68EN360CAI25L%20%E7%9A%84%E6%9B%BF%E4%BB%A3%E5%93%81%EF%BC%8C%E5%BE%88%E9%81%97%E6%86%BE%E6%B2%A1%E6%9C%89%E7%9B%B4%E6%8E%A5%E7%9A%84%E6%9B%BF%E4%BB%A3%E5%93%81%EF%BC%88%E5%BC%95%E8%84%9A%E5%AF%B9%E5%BC%95%E8%84%9A%E5%85%BC%E5%AE%B9%E6%88%96%E4%B8%8D%E6%94%B9%E5%8F%98%E7%A1%AC%E4%BB%B6%2F%E8%BD%AF%E4%BB%B6%EF%BC%89%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%85%B3%E4%BA%8E%20MC68360CRC25L%20%E4%BD%9C%E4%B8%BA%20MC68EN360CAI25L%20%E7%9A%84%E6%9B%BF%E4%BB%A3%E5%93%81%EF%BC%8C%E4%BB%8D%E5%AD%98%E5%9C%A8%E4%BB%A5%E4%B8%8B%E4%BA%A7%E5%93%81%E5%B7%AE%E5%BC%82%EF%BC%9A%3C%2FP%3E%0A%3CP%3EMC68EN360%20%E6%98%AF%20MC68360%20%E7%9A%84%E4%BB%A5%E5%A4%AA%E7%BD%91%E7%89%88%E6%9C%AC%E3%80%82MC68EN360%20%E6%98%AF%20MC68360%20%E7%9A%84%E8%B6%85%E9%9B%86%E3%80%82%E4%BB%A5%E5%A4%AA%E7%BD%91%E4%BB%85%E9%80%82%E7%94%A8%E4%BA%8E%20MC68EN360%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%85%B3%E6%B3%A8%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EMike%3C%2FP%3E%3C%2FLINGO-BODY%3E
