Math library for MCF5329
2,214件の閲覧回数
cktrod
We seem to be having speed problems doing floating point math on the MCF5329 using the Microtec compiler (Mentor Graphics Edge IDE).  Is there a free math library with source code provided by Freescale that I can compile with my code-base to compare performance?
Rod
1,703件の閲覧回数
sirlenzelot
Hi Rod,
I'm sorry, I can't help you with a free math lib. But I read that you are using EDGE IDE. Do you have problems with the development under EDGE, too? Maybe we can talk about EDGE? Do you know a good place where to discuss things about EDGE?
Dirk
1,703件の閲覧回数
cktrod
Dirk,
Don't get me started on Edge.  I notice that Mentor Graphics doesn't have a community set up on their forum to discuss edge.  Gee, I wonder why.
Too expensive
Slow loading
Slow debug stepping after a few debug cycles
Memory Leaks
Crashes just as you're getting close to the bug
Variables with unknow values
Variables with incorrect decoding
Intermittenly grayed-out memory window
But this probably isn't the place to discuss it.
Happily moving away from Edge,
Rod
