MCF5484 USB
MCF5484 USB
2,832 次查看
mhench
I am writing a USB driver for the 5484. On the very first OUT message to endpoint 0 (a vendor request)
I get the setup data then see the fifo get the 24 data bytes I am supposed to get, then ~1usec later,
it goes down to 20 bytes without any registers being touched. Interrupts are off.
when I read the data I never see the first longword.
does anyone have any ideas ?
is there a complete test app for USB on this chip yet ?
Thank You.
1,641 次查看
Rik
Hej.
The old MCF548x chips had USB bugs. Check the date code you have on the chip and check the errata list on the web.
Rik.
1,641 次查看
volk
Hello
I advice select another USB controller for expriences
this is a first bugs you found
Every time you will found another one.
