MCF5373L as target processor?
KRichard
Hello, I use CodeWarrior for ColdFire special edition.
In the Tools -> Flash programmer window I can't choose 5373 as my target processor, what should I choose instead?
Thanks!
macl
Senior Contributor I
If you are using the 5373 EVB, you should be able to select MCF532X as your target processor.  The 537X & 532X share the same flash drivers.
