MCF5307, little help
angelo_d
Senior Contributor I
Hi all,
i am debugging a prototype with MCF5307 and a 16x2 Flash memory.
The flash is connected to CS0, *WE, *OE, etc. but no read operation from the flash is working.
This is the CS0 configuration:
 * ChipSelect 0 - FLASH  */ MCF_CS0_CSAR = BASEADDR_FLASH>>16;  MCF_CS0_CSCR = 0  | MCF_CS_CSCR_WS(6)  | MCF_CS_CSCR_AA  | MCF_CS_CSCR_PS_16;  MCF_CS0_CSMR = MCF_CS_CSMR_BAM_4M | MCF_CS_CSMR_V;
As a first test, i try to read the part ID from the flash, but i don't get anything different data than 0xffff.
So i started to look at signals with the scope, with this test loop:
volatile unsigned short *baseaddress = (volatile unsigned short *)BASEADDR_FLASH;while(1)   *(baseaddress + 0x555) = (unsigned short)0xAA;
In this simple loop, CS0 is correctly driven up and down at every write, but *WE remain high.
Every help is really appreciated,
many thanks,
Angelo
angelo_d
sorry, was wrong, the signal was correct, problem was on my bad code.
regards,
Angelo
angelo_d
regards,
Angelo
