MCF5234 PIT Problem
MCF5234 PIT Problem
2,801 次查看
sirlenzelot
I try to get PIT0 running. Everything works fine so far. As PIT Counter reaches 0 my ISR is called. Bus as it is leaved, I get Interrupt 2 (Access Error).
Do I need to do anything else but set PSCR.PIF = 1 in my ISR in order to reset the PIT Interrupt?
PIT0 Setup and ISR:
Code:
PMR.OVW = 1;
PMR.PM = 0x8F0D;PCSR.PRE = 0xB;PCSR.PIE = 1;PCSR.DBG = 1;PCSR.RLD = 1;PCSR.EN = 1;void PIT0_isr(void){     PIT0.PCSR.B.PIF = 1;}
Did someone have a similar problem and solved it?
Thanks for your help.
best regards (vy73)
Sir Lenzelot
1,376 次查看
stzari
Don't you have to declare the handler as an interrupt function ?
(I haven't worked with CodeWarrior, so I can't tell you how to do this).
HTH
Stamatis
1,376 次查看
sirlenzelot
Hi Stamatis.
That was my mistake.
Thanks for opening my eyes.
Have a nice weekend.
best regards (vy73)
Sir Lenzelot
Message Edited by sir lenzelot on 2007-03-2302:14 PM
