MCF5223X and external RAM/FLASH
2,131 次查看
sili
Is it possible to interface an external SRAM or FLASH to this family of MCU ?
Thanks in advance.
Peter.
1,549 次查看
scifi
Senior Contributor I
Since the MCF5223x family lacks an external bus, you can only interface external memory through SPI, I2C, GPIO or similar. That means you can't execute code directly from external memory and access to it would be rather slow.
1,550 次查看
scifi
