MCF52223 & RS232
MCF52223 & RS232
4,158件の閲覧回数
plaurium
Hi guys,
I'm just starting out so any help would be great !
I'm trying to write some simple code to send and receive data from the serial port.
I have a MCF52223-SK development Board (from IAR).
Thank you
4 返答(返信)
2,452件の閲覧回数
jbezem
"any help" is good... What environment do you have? Which version of that environment? What documentation did you read but have difficulties with? What did you try? What problems did you experience that you cannot seem to solve?
Surely, you're not expecting us to write your simple application for you?
BR,
Johan
2,452件の閲覧回数
plaurium
Thx, I'll try to be as direct and simple as you,
I have the "IAR Embedded Workbench® for ColdFire" it was provided with my kit, here's the link:
http://www.iar.com/website1/1.0.1.0/658/1/?item=prod_prod-s1/244&group=prod_prod_grp-s1/35
I found a doc in the cd they provided, but I'm having trouble understanding it. (it's attached)
What did you try?
Understand the document ( how the uart modules work on my kit )
I don't know how to reach the uart module, and extract or send data to it.
Well I was hoping if somebody is familiar with this kind of applications, will give me a start point.
It might seem that I'm just waiting for your code, but I'm really working hard on my own.
2,452件の閲覧回数
mjbcswitzerland
Specialist V
Usually I would say that you can get everything you need at www.uTasker.com - the UART user's manual is http://www.utasker.com/docs/uTasker/uTaskerUART.PDF
However I haven't actually heard of anyone using the IAR kit before, so have to admit that there is no IAR project included. However the simulator still allows running and testing an M52223 (including UARTs), which will allow all operation to be studied and understood before moving it to the IAR environment.
Mark
2,452件の閲覧回数
plaurium
<bump>
