MCF51JM Drivers
MCF51JM Drivers
2,014 次查看
a_sangros
Hi!
Using this micro in Windows 7 and 8 it's not possible to be recognized. Under Windows 10 is okey. I haven't found drivers for Windows 7 and 8. I need your help.
Thanks in advance.
1,908 次查看
Hui_Ma
I think you are using MCF51JM for USB device application.
Please check if this issue also happened at [Flexis JM Demonstration Board].
Please check MCF51JM USB circuit design and USB communication signal quality.
Thank you for the attention.
Mike
1,908 次查看
a_sangros
Hi, @Hui_Ma
Thanks for your answer. I've written an inf file to link the sys file of the driver and it works! Solved in w7 64 bits. I'll test it in other versions.
 Arturo
1,908 次查看
Hui_Ma
Hi Arturo,
Nice to hear the issue had been resolved. Thanks for the info.
best regards,
Mike
