MCF51AC--MCLK pin
MCF51AC--MCLK pin
1,938 次查看
drazenletina
Hello ,
I would like to know to which module belongs pin MCLK  and what is this pin ,i.e. pin 62: PTC2/MCLK  on the  64-pin QFP/LQFP of MCF51AC .
Thank you ,
          Drazen
1,836 次查看
drazenletina
I have found. It is described on the pages 5-13 and 5-14 of MCF51AC256RM.pdf  .
This signal is connected  with the bus frequency :
MCLK frequency = Bus clock frequency /(2 * MCSEL) .
1,837 次查看
drazenletina
1,836 次查看
TomE
Specialist II
In Adobe Acrobat, Control-F will let you search a document for keywords, and Control-Shift-F will bring up a window with all matches. There are 21 matches for "MCLK" (whole word, match case) in the Reference Manual.
Tom
