MCF 5235 - ADC
MCF 5235 - ADC
4,405件の閲覧回数
mcf5235
can someone please let me know the possible ways I can use MCF5235 board for an ADC.
Thanks a lot in advance
3 返答(返信)
1,898件の閲覧回数
PaoloRenzo
Contributor V
Yes you can do that way. Or depending your application needs, you can use those QSPI pins to drive a SPI ADC external chip.
Good luck
1,898件の閲覧回数
PaoloRenzo
Contributor V
Well you can do it using some GPIO pins as input and using and external ADC chip. 5235 doesn't have internal ADC module, as you should know.
Good luck...
1,898件の閲覧回数
mcf5235
Mr. Paolo,
Thank you so much for your response.
What you say is just configure the QSPI as GPIOs and use to interface an ADC to it. am i right?
Thankyou
