M52223EVB
M52223EVB
Bartington
HI the evaluation board production is pending, Does anyone know the approximative date of release and the closest equivalent board? As we are a bit stuck at the minute.
Thanks loads
Olivier
UK_CF_FAE
You should find the M52235EVB readily available. I have one. 52233 = 52235 with no CAN and no CAU. M52235EVB is listed on DevToolsDirect.
Good Luck
Mark
