M2233DEMO
M2233DEMO
3,966 次查看
bagula
I have Vista OS and I am facing problem with installing M2233DEMO as there is no hyper terminal in Vista OS. need help.Thanks
4 回复数
3,044 次查看
Daniel2312
Another programm that run under vista is HTerm.
HTerm
3,044 次查看
butok
You may try any other Terminal program.
For example, the opensource&free “Tera Term Pro”.
The latest version you can find here: http://ttssh2.sourceforge.jp
Andrey Butok
3,044 次查看
bagula
thanks. i shall try.
bagula
3,044 次查看
RichTestardi
Senior Contributor II
I also use putty: http://www.putty.org/
Putty now supports serial ports as well as sockets.
You can also actually copy HyperTerminal from an XP box to Vista, and it will work as well.
-- Rich
