LCDC in M52277EVB
LCDC in M52277EVB
admin
Specialist II
I recieve the M52277EVB a few days ago. I can programm the flash, the sdram and execute several examples in the board. The problem I have is the LCDC initialization. I did not find any example code using the LCDC, I try to make it by myself but It does not work... Where can I find an example using LCDC for the M52277? (I´m using Codewarrior v7.1).
Thank you very much in advance.
ianlovatt
There were example projects (eg. m52277evb_photo_album_cw7.mcp) that used the LCDC on the CD that came with our M52277 EVB.
ian
